#118988 05/20/02 10:03 PM
m.adair Offline OP
I don't want to go over 100 different opinions on what induction system I should use. However, can someone tell me what system is far and away the most popular on the list? I just want to cut to the chase and buy one. Thanks-
87 honda civic si
88 bmw m3
89 alfa milano 3L verde
98.5 ford contour svt
93 honda NSR 250sp
#118989 05/20/02 10:27 PM
KKM
Simon W. Las Vegas.
96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!)
1999 SVT Engine
SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT
"it's only nuts and bolts" - Terry Haines
"Drive it like you stole it" - Me!
#118990 05/20/02 11:45 PM
I agree. KKM, by far.
#118991 05/20/02 11:56 PM
KKM = Most popular
Doesn't mean its the best though!
If I were you I'd grab up a BAT Maf adapter and some sort of 8-9" filter. K&N's are nice and a new filter SilvaBullet sells (AFE filter) is said to give nice gains. The KKM seems to be good for a while but why not go with something that gives you room to build on!
Hope that helps!
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#118992 05/21/02 03:01 PM
m.adair Offline OP
Thanks for the input. KKM good for a awhile? Is this because of the filter? What is the advantage of the BAT MAF? Lastly, what is the best retailer to find the KKM at? In stock and ready too ship.
Thanks, Michael
87 honda civic si
88 bmw m3
93 honda NSR 250sp
#118993 05/21/02 03:18 PM
I have a KKM and when it gets warm out I was experience heat soak and my car would bog down so I just ordered a heat shield for it from Stazi, hope that helps. It's a good intake with a great sound and it only takes about 15min to install but if I were you I would look into BAT intake kits a little more, espicially the one with remote air. Hope that helps, with any open air filter you will experience some heat soak in warmer climates but whatever intake you get you'll probabley be happy with it, if not just for that sound.
1998.5 Silver SVT
Brullen exaust
KKM intake
Off Road Y-pipe
5% mirror tint
#118994 05/21/02 05:12 PM
Thanks, Michael
If you plan on doing any exhaust modifications or any more flow modifications at all, the KKM S&B filter size & design will not provide enough flow. The filter design makes it die at higher rpms and the filter size yeild lower gains obviously than a larger filter.
If you search you'll find several posts about this subject.
Again the KKM is a great kit, but its not for someone who plans on modifying their very much. I'm only saying this because I wish I knew this before I bought it. Now I am to the point where I need to buy a new filter, in order to fully take advantage of all my gains.
So why not do it from the start?
Like I said check into the BAT Maf ADAPTER w/ Screen gasket holder (I wouldn't get their filter kits), then look into a 7-9" K&N or AFE filter, and make or buy a heatshield. If you do this you'll have a good building block!
The BAT tubing is a nice design but you can buy the tubing from Home Depot and run your own.
If you do get a larger filter you may have to do some trimming. Again if you run a search I'm sure you'll get plenty of info on this subject.
Hope that helps
Justin
1998 Black SVT
#118995 05/21/02 07:56 PM
m.adair Offline OP
Justin/Silva,
Thanks for the info. It's all coming back to me now. My 3.0 Milano Verde had an super hot engine bay and I remember the heat soak problem and trying to pipe the cooler air remotely. I can't remember the exact stats but the hp loss for every 5 degrees of added heat was terrible. So BAT now makes a pipe. Interesting. I will speak to them. Thanks again-
87 honda civic si
88 bmw m3
93 honda NSR 250sp
