Page 2 of 2 1 2
Originally posted by AirKnight:
Seems a little expensive for aluminized steel not stainless steel... But I guess I should say it's expensive consider the Brullen I got cost me $617 installed.
So half price for aluminized mandrel system. That's a decent option IMO.
It may be a bit loud though.
2000 SVT #674 - Check it out!
It's a nice looking system - Yodude is quality stuff, but for sre it will be loud with just one Flowmaster. Drone on that thing would be INSANE!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
I had a setup much like that a little while ago. The drone wasn't too bad, until you drove around w/ the rear seats folded down. They it got kinda loud in the cabin. 310 seems like a good deal to me.
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
H
H
My custom 2.5" single exhaust was approx $250.
Dynomax Resonator $55 after rebate, Dynomax Muffler $20 after rebate, $80 mandrel bend piping from JCWhitney, $20 for 7' 2.5" pipe, $20 chrome tip and $40 labor at a local shop.
No rasp, little drone, pics coming. 3k rpms has a boomy sound, but 250 rpm + or - takes care of that.
FWIW, single 2.5" mandrel bend, flows approx. the same as 2.25" dual.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
For some reason, I think a single in/dual out muffler won't make as much or help as much as a single/single due to the physics of air and fighting over two opening instead of a single larger opening. Correct me if I'm wrong (it's been a while since my last fluid dynamics lecture).
'99 Contour SE V6 w/MTX (Black Clearcoat)
'02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
Actually single 2.5" pipe flows as much as dual 1.77" pipes.
Dual 2" pipes flow as much as a single 2.83" pipe.
Dual 2.25" pipes flow as much as a single 3.18" pipe.
H
H
But coming out of the y-pipe and out of the resonator, and before the y split it is all 2.5" pipe before it splits to two 2.25" pipes. I see that the restriction is before it splits then. So 2.5" pipe is the minimum diameter in a stock SVT exhaust or even a custom one because of the y-pipe and resonator diameters.
Right?
Page 2 of 2 1 2
