Radiator replacement How-To..
CLICK THE PICTURES FOR FULL SCREEN VERSIONS!!!!Radiator
Removal
1. Disconnect the battery ground cable.
2. Drain the cooling system.
�?µ 3. Disconnect the fan resistor electrical connector. (just below, and the to side of the radiator fan)
4. Lower the vehicle.
�?µ 5. Disconnect the cooling fan electrical connectors. (two seperate connectors next to each other, each with plastic mating clips)
�?µ 6. Disconnect the ground cable. (re-torque to 12Nm)
Vehicles fitted with A/C
�?µ 7. Disconnect the A/C electrical connector.
�?µ 8. Disconnect the A/C low pressure switch electrical connector.
All vehicles
�?µ 9. Unclip the cooling fan and fan resistor cables.
Vehicles fitted with automatic transaxle
�?µ 10. Disconnect the transaxle upper cooling line. (re-torque to 27Nm)
All vehicles
�?µ 11. Disconnect the radiator lower hose.
Vehicle fitted with automatic transaxle
�?µ 12. Disconnect the transaxle lower cooling line. (re-torque to 27Nm)
All vehicles
�?µ 13. Disconnect the radiator upper hose.
14. Raise and support the vehicle. For additional information, refer to �?«Section 100-02�?».
�?µ 15. Secure the A/C condensor.
�?µ 16. Remove the A/C condensor bolts. Re-torque to 4Nm)
l Remove the two bolts.
All vehicles
�?µ 17. Remove the radiator.
l Remove the four bolts. (re-torque to 10Nm)
l Remove the radiator.
Installation
�?µ 1. To install, reverse the removal procedure.
Ray
