Page 43 of 48 1 2 41 42 43 44 45 47 48
#1188601 04/12/05 11:01 AM
Jason43 Offline OP
Originally posted by hmouta:
so to get the hl switch i have to start a new development list even though its just been developed? and its gonna cost me 40 plus 8 shipping. 48 for a freaking hl switch? so i cant just order one? i need to find another 9 people?
Just sign up for one on the model developement page. They made a batch of 50 and should have several left over.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#1188602 04/12/05 01:12 PM
W
W
Originally posted by mygameisplatnum:
it gives more options to make the parts match. I wanted this so I can pick which color looks best. You never can be too sure how good the colors will come out w/ these things. Also w/ the 6 color inverter I only have to use 1 inverter to run all the gauges, the HVAC and the HL ( via the 2 y-splitters the lady is throwing in for me). they will all be color controlled simultanueously aka all 3 pieces will change at the same time and match perfectly.
I just got mine yesterday. Haven't had time to do anything yet. I have one inverter for each piece. If you can use y-splitters for these things, why would they go to the extra expense of including inverters for each piece. Any chance of overloading the inverters by putting more than 2 or more pieces on it?
WA 2 TUFF SVT 2000 Tropic Green SVT Born 1/28/2000-1975 out of 2150-only 207 made. Some new pics
#1188603 04/12/05 06:07 PM
I think your confusing the y-splitters w/ inverters. The gauges have 4 plugs (which takes up the entire inverter..b/c it only has 4 openeings), in order to get the HVAC and HL to work you need to have 2 y-splitters to branch off from the 1 inverter running your gauges (1 y-splitter for the HVAC and 1 y-splitter for the HL which will essentially give you 6 openings instead of 4 to hold all 6 plugs from all the parts)thats why i said i think you are confusing the 2. Unless you have 3 pieces that all have a switch to change the colors. I havent seen them yet since I ordered them a few days ago but thats the logic behind it. Either way I spoke w/ the co. and im sure their sending me what I need to make it work.
Justin 98.5 CSVT # 4887 of 6535 (born 2/28/98)
#1188604 04/12/05 08:27 PM
i emailed them asking about the color difference between them and this is the response i got:
The gauges were started into production before the a/c unit and switch plate. Each time they run the units the colors are off just a little. There is not controlling it. The reason they were started at different time is because we were waiting on the Headlight switch, the gauges had already started at that point. The best I can say is change the color on the gauges to match the color on the a/c panel a little better! We do have a plug that will split the 4 plugs into 7 plugs giving you enough to urn it all off the one inverter, but then you can not change the gauges to match the a/c unit! they will always look off color, so it is better they way you have it now!
FORMER OWNER 2000 Black SVT #934 of 2150
#1188605 04/12/05 08:31 PM
Yikes, they sounded a little pissed in that email. Oh well, I'm fine with it for now. Once someone figures an easy fix for this i'll attempt it. Besides it doesnt bother me all that much... Kinda sucks that some people havent even got these yet, and i've had them installed since saturday!
#1188606 04/12/05 10:42 PM
9
9
I got mine today. It came with one main inverter with four plugs and two other small ones with one each. Is that everything you need to make it work? Also did anyone notice that the svt symbol is red along with the km/hr. My stock ones are all black.
#1188607 04/12/05 10:54 PM
The red color SVT lettering on the indiglos is similar to the "glowing SVT tach mod".I did the glowing mod on my stock gauges and it looks awesome. When this mod is not done the SVT is lost at night and is not visable. W/ this mod done it is still black during the day but glows red at night when the lights are turned on.
So the indiglos SVT lettering are basically the same way except they are always red. Red during the day and glows red at night. Its better this way i feel...thats my .02
#1188608 04/13/05 01:01 AM
Jason43 Offline OP
I actually like the red accents better.
#1188609 04/13/05 02:22 AM
thats what most of us got lil buddy, and yes it will work. u may want 2 contact them about getting some splitters so the colors r more closely matched. other than that, they puppies r bad ass and really bright!
#1188610 04/13/05 03:07 AM
I just noticed when my tach is at 3K or higher the needle is sticking I made sure to use double sided tape so the gauge face wouldnt sag causing this problem. I'm not pulling everything apart again just to fix this. Other than my sticky tach, I'm very happy with this set. THEY ARE BRIGHTER THAN ANY OTHER INDIGLOWS IVE HAD OR SEEN
1999 CSVT-Black 15.8@89mph Driver for hire. PM me.
Moderated by  1314_dup1
