Posts: 307 |
I've built one for my tour, but just haven't put it on her yet.
'99 Contour SE V6 w/MTX (Black Clearcoat) '02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
Posts: 306 |
Originally posted by Terry Haines: The seperator needs to be between the pcv port and the pcv valve so the soilds can drop out to the bottom(with a drain cock,also the vapor connection from the purge sol still must be retained....... Can someone translate what Terry means for the less technically minded! Having been impressed with DemonSVT's previous post, I have just come back from the USA and brought with me the oil separator in kit form! I am building it tomorrow; all I thought was it fitted in between the top of the PCV valve and the upper intake? Am I not correct? Paul.
Posts: 2,066 |
Does someone sell these already built? Also how often do you have to drain it?
Thanks
Posts: 316 |
I got my PCV oil seperator for $30 from Anastazi this week.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 2,066 |
Whoops missed that one.
Thanks...how about the other question?
Posts: 316 |
It have yet to install it. I am waiting for my Aussie inlet pipe. Demon should know.
Posts: 5,805 |
Yes between the pcv and the intake manifold port....
Posts: 3,567 |
Isn't the job of the PCV valve to 1, scavenge out any oil vapors or other flamable vapors to prevent crankcase fires. 2. to help maintain a negative pressure (relative to ambient atmospheric pressure) which hepls make a pressure differential between the top and bottom of the piston. The theory being that the effectiveness of the piston rings to make a seal is partly dependent upon the pressure differential between the top and bottom of the piston.
Or is there more to it than that?
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 7,329 |
Originally posted by JSmith: Isn't the job of the PCV valve ...
Or is there more to it than that? Yes. That is exactly the how & why. Also with a properly setup PCV system you could make more power (better ring seal, less crankcase pressure behind the pistons) This is why the system is retained. It is just now "filtered" as well. I just emptied my tank. 1+ oz in 3 weeks(800 miles). Neglible pan loss (.5% of ~200 oz capacity) However when you think of dumping 1 oz of oil down the intake it does seem like a lot. That's like dumping a 1/2 quart of oil in every year (10k miles).
Posts: 316 |
Since I drive 3000 miles a month that works out to like 4 oz a month or a quart every 6 months. I need to get that installed, no use sitting on top of the tool box.
