Posts: 4,639 |
sorry i'm jumping in on this late. i got some questions and input too.
i ordered indiglos from sr like 2 years ago but they didnt fit when i tried to install them. the quality is good but their design was bad. i'd be willing to donate them back to s/r but they MUST change the wiring placement and make them 2 main gauges instead of 4 (i'll explain)
all they would have to do is copy the indiglos they've already made in the past.
lemme explain something. the indiglos that everyone already has was made as 2 main gauges, meaning the tach and temp gauges was made as one indiglo gauge with one wiring output to the transformer. and the same goes for the speedo and fuel gauge. s/r made each of these an individual gauge meaning that one transformer will power all 4 and you wont have room to plug in the hvac and the headlight (pls dont start that this is the wrong way to do it, we've all heard the arguments). anyway, s/r placed the wiring for the gauges in the wrong spots. when i contacted them, they swore their gauges get tested and installed before actually selling them and shipping them. i say bs. they wiring would jut out from one gauge into the space of the neighboring gauge not allowing the neighboring gauge overlay to sit flat. there was no way in hell that the gauges were going to be installed properly. (i'm far from stupid; i knew exactly what i was doing and can easily tell that a cirle wont fit in a square opening) they wouldnt refund my money either. they've sat in my bedroom since then. i was lucky enough to get in on one of cardoc's gb. his gauges were made correctly as 2 main gauges with the wiring connection at the towards the bottom right and left of the tach and speedo, respectively. i just took a pic to show u guys. can someone host it on here.
if they make them this same way (if they havent smartened up) u guys r gonna need to run at least 2 transformers: one for the 4 main gauges and one for the hvac and headlight with 2 open plugs on the 2nd transformer. if they make the 4 main gauges as 2 gauges as i described, then u guys can run one transformer. i have the 4th plug open on my transformer and i've been waiting to use it for the headlight switch.
that said, i'm interested in the headlight switch. i clicked on the link and it had only the hl/hvac set and that i'd need to start a new production for either item. is this correct. the spots where cardocs hvac and main gauges have the wiring are perfect. i took a pic of my spare hl switch pointing to where the wire should be attached, but basically to the right of the overlay and centered. the hl switch side is flat there so the wire should be easy to bend back for installation.
i wouldnt mind trading the 4 s/r main gauges for a headlight gauge if sr can use the gauges to improve them. should be easier for them than making a template off the gauge cluster. they didnt want to listen to me the first time around. also i have an extra headlight switch that i bought just for this very purpose, if its still needed.
and i also have the hard copy install directions for the indiglos that were originally on fco. i dont know if they are still on there. they actually show a great pic of the speedo/fuel indiglo gauge and what s/r "should" make it like and where to place the wiring connection.
also the white "dummy" overlays are a bit too much. they did come with my lights and i only used them for the left/right turnsignal at the top. i think they look understated this way. plus the traction control overlay has a typo and the abs & oil lights were put in the wrong place. they have to be swapped on the overlay. another reason to not use the dummy overlays.
i'd be more than willing to scan the install instructions. i can likely put them up in my webshots acct which is in my sig
Hugo AIM:omegazodiac
Posts: 685 |
Originally posted by hmouta: sorry i'm jumping in on this late. i got some questions and input too.
Can someone contact SR to find out if they have corrected this problem w/ the wiring, transformers, etc.?!?
No one wants to spend over $100 on all this if its going to be a problem and not work properly.
Also the pics HMOUTA took could add to the effectiveness of SR fixing the problem. Someone needs to act fast as they sent me an e-mail yesturday and said the set will start production tomarrow (today)
Justin
98.5 CSVT # 4887 of 6535 (born 2/28/98)
Posts: 1,609 |
If someone wants those little white things on the bottem PM me... I have some I can sell for a small fee
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 685 |
Guess no one is worried about what HMOUTA said. As long as everyone is happy w/ gauges that may not fit and not work then ok. I myself would call and speak to them about the possible problems, however, I am not very knowledgable on the subject of indiglos and how they function so it would pretty much be pointless. If someone knowledgeable on Indiglos wants to call to make sure these are being produced right then great. If not all you who have been charged on your CC may be waisting your $.
Justin
Posts: 328 |
I have 3 other sets of indiglows from 3 other companies that are fk'd up and collecting dust in my closet. These companies wouldnt accept returns btw, told me all sales were final. If S/R sents me a fk'd up pair and doesn't refund me, I'll be taking a drive to their office for sure.
1999 CSVT-Black 15.8@89mph
Driver for hire. PM me.
Posts: 685 |
Originally posted by BURNTU2: I have 3 other sets of indiglows from 3 other companies that are fk'd up and collecting dust in my closet. These companies wouldnt accept returns btw, told me all sales were final. If S/R sents me a fk'd up pair and doesn't refund me, I'll be taking a drive to their office for sure.
Which is EXACTLY why im saying someone knowledgeable on this subject NEEDS to speak to S/R and make sure these are being done right. If not you all who ordered are going to be screwed over.
Justin
Posts: 6,791 |
I'm concerned about what was said BUT my card was already charged there isn't any turning back. Besides i didn't read that whole post it was huge!!!
Posts: 15 |
I found these gauges...they look like they have the SVT on them. http://www.speedinfiniti.com/98focosvt6pr.htmlDoes anyone know how hard these are to install?
Posts: 4,051 |
Originally posted by HoustonBullitt: I found these gauges...they look like they have the SVT on them.
How the hell did you find those? Sooo many people have been looking for the longest time and turned up nothing. My guess is that when you order those, they will say they are no longer in stock, kinda like other places.
BTW, those are identical to the ones in my car and they are great.
Posts: 1,423 |
Originally posted by CSVT1214: Originally posted by HoustonBullitt: I found these gauges...they look like they have the SVT on them.
Same ones I have as well...I got mine from a buisness on eBay for about the same price. The greens are nasty and the blue isn't quite blue enough for me. The have been in my car for the last 2 years.
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
