SVT19 Offline OP
Does anyone else have this combo on thier car and if so can you close the hood without the filter hitting it because my filter hits the hood when I close. Is there any solution to this.
'98 E0 Black SVT Contour
BAT Air Inlet Pipe w/ITG Filter
If you still have a hoodliner, remove it.
Otherwise, you may have to insert a flexible hose section somewhere, similar to the one you removed when you went to the "hard" pipe.
I have the ITG filter and even without the hoodliner, it appears that a slight bend is necessary in order for everything to close.
"Function before fashion."
'96 Contour SE
