#1187601 02/16/05 03:37 AM
0
did anyone else find installing these an absolute PITA?
i wish i wouldve had the mechanic at work do it for me.
it was alot more time consuming than i read from other peoples experiences, and installing the oil pressure sending unit took FOREVER.
all in all, i cant complain bc it looks great and was well worth it.
2000 SVT Contour. Black. #1889 of 2150.
#1187602 02/16/05 06:43 AM
i didnt think it was that hard. Hardest part was fitting the gauges in the pod. I had to actually sand the openings a bit to get them to fit.
Where did you tap the oil pressure gauge?
#1187603 02/16/05 06:58 AM
did mine a week ago and wasnt too hard to install just the pod and gauges but didnt install the wiring yet until the days are longer in the spring or early summer.
-dan
98 CSVT 484/6535,18" MI Rims,Nitto NEO GEN Tires,Pioneer DEH-P7300,Custom Cougar CIA,CF Hood,McCULLOCH HID 6K,Custom painted red calipers,Flowmaster 40s mufflers,Drilled Slot rotors,K&N 9" air filter,Brullen HiFlo Y Pipe & CAT,Magnaflow Res
#1187604 02/16/05 07:23 AM
i didnt really think it was hard, but it is a pain in the A. this is mainly cause i HATE wiring. you can find my troubles in a thread or two i started about the oil pressure gauge.
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
#1187605 02/16/05 12:50 PM
I've installed volts and A/F but haven't got around to the oil pressure yet... I'm waiting for a warm day. The oil is really the only PITA... Otherwise i found it pretty easy... Oh and no need for a mechanic on this
#1187606 02/17/05 02:21 AM
0
i realize there was no need for a mechanic, but the oil pressure really was a pain. i tapped in down by the a/c compressor.
like i said it was a pita, but well worth it.
#1187607 02/20/05 02:48 PM
W
W
You should have tapped in on the rear of the cylinder head, same place we tap for the oil supply to the turbos.
It also gives a good indication of oil supply pressure to the heads.
#1187608 02/20/05 10:22 PM
0
yeah, i was going to do that, but i heard doing it on the bottom gives a quicker reading. quicker as far as if i were to lose all oil pressure i would know right away, whereas if you do it on top it takes longer to read that.
