Posts: 42 |
Well I'm ready to spring for a new clutch. I got a 99 SVT with 70k miles and the stock clutch is shot. I don't want to get the stock clutch but I would rather get an aftermarket clutch that has proven itself worthy in other Contours. I don't want a pure racing clutch. I'm not taking it to the strip. I just want something that will have a better "grab" than the stock clutch. Keep in mind the funds are low. I'm planning on buying the clutch and having a local shop do the install.
Another question. Does anyone have any idea on how involved replacing the clutch is on an SVT? I mean, do they have to completely remove the entire transmission. I just don't want any hidden charges and I don't want to go into this blind folded. This is a lot of money for me so I want to make sure I'm getting the right part for my needs.. Thanks guys..
99 SVT Silver Frost Knauberized Doors, Xenon Headlights, TH Fix, KKM Filter, Resonator Removed, B&M Short Throw Shifter, Fidanza Flywheel, RAM HD Clutch --STEREO MODS-- Clarion HU with DSP module, RF 5x7's all around, 1 Kicker Sole-Baric L7 Woofer, 2 Kicker Comp 12s 2 MTX tweeters in dash, 1 MTX 4160 for highs, 1 RF 200ix for Solo-Baric 1 MTX 2160 for Comps 1 Farad Capacitor OEM battery & optimus gel cell.. Culguy76@hotmail.com
Posts: 15 |
I have a Centerforce Dual Friction clutch in my Mystique and have been very happy. Installation was pricey though because it's something like eight hours of labor. From my understanding the tranny is not that easy to get to.
1996 Mystique GS V6 MTX - PIAA bulbs, SVT shift knob, Firestone Firehawk tires, EBC Greenstuff front pads, Amsoil oil filter, Centerforce Dual Friction clutch, SVT flywheel, Amsoil synthetic transmission fluid.
Posts: 1,355 |
I had mine replaced by a clutch "specialist", I did the same thing, bought clutch kit and had them install it. They were the ONLY place I found that would give a warrenty on the work also. All be it for only 6 motnhs, but that was better then nothing. If you can find a shop that will give you warrenty, go there. But MOST will not (if you buy your clutch yourself that is).
It took them 9 1/2 hours to do it = $650 in labour. It's not easy. Honestly though, I believe that a "specialist" should have been able to do it alot quicker then 9 1/2 hours. So take that as the worst! (Ford's book time for a clutch job is 9 hours.)
A CEG'er called Dustyn had his tranny off in 4 1/2 hours I think he said it took. That's with 2 guys helping him also.
You basically have to drop the subframe to get the tranny off, removal of the transaxle etc so yes the entire "transmission" has to be removed.
All depends on your budget. At the time I had mine replaced, I was on a tight one too so I only got a "slightly" better clutch kit installed, Grizzly OEM from Spmotorsports.com $300. It's not bad, never had any problems with it. Feels good, grabs a little harder then stock. Now I am swapping my engine out with an SVT one I'm going to get a better clutch again. I think I have decided on the RAM Power Grip HD Clutch. For $360 and has a great reputation with the Mustang group so it can't be bad. (I can't see myself spending $500-600 on a clutch that will be too hard to drive as a daily, I don't go to the drags THAT much).
Good luck with it all.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 651 |
I got a Grizzly OEM clutch from SP Motorsports. I've like it so far, defiently bites better than stock, grips better changing gears. Can't comment on the installation costs though. My tranny was pulled for the 3rd gear syncro replacement under warranty. Had my friend at the dealership throw the clutch in while he was in there. Total cost for me $0. It's nice to have a good friend at your Ford dealership.
99 SVT...modified 96 GL....the beater "I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
Posts: 1,355 |
Posts: 42 |
Ditto.. I'm not that lucky.. Actually, Ford told me the total cost would be $1,390. I told them to ki$$ my a$$.
Posts: 1,355 |
Originally posted by culguy76: Ditto.. I'm not that lucky.. Actually, Ford told me the total cost would be $1,390. I told them to ki$$ my a$$. That's with THEM replacing the clutch though right? Sounds about right if they do everything. Robbing b*******!
Posts: 563 |
Originally posted by Simon96SE: I had mine replaced by a clutch "specialist", I did the same thing, bought clutch kit and had them install it. They were the ONLY place I found that would give a warrenty on the work also. All be it for only 6 motnhs, but that was better then nothing. If you can find a shop that will give you warrenty, go there. But MOST will not (if you buy your clutch yourself that is).
Good luck with it all. simon simon simon no no i done it in 5-1/2 to six hours. I am not that good or neither is my crew. I think it can be done in 7 hours taken out and put back in with a lift of course. Terry haines can do it in 2-1/2 hours thats pullin it out. But thanks for the boost of the ego god knows I will need it next week when the trans goes back in. We didn't mark anything and the trans has been out for two months now. There are cob webs in the exhaust pipes. can't wait to blow them out.
Dustyn Red 1998 SVT E1 95 Mustang GT Yeah there both slow New ram clutch for sale Sho shop pullies and belt for sale 30 bucks
Posts: 42 |
Well I decided to buy the parts from SPMotorsports.. I'm gonna get the Fidanza flywheel and the Grizzly clutch. But the hardest part about this is that they won't answer their frickin phone. I have been calling all day yesterday and today and I keep getting a message that they are assisting someone else. I leave messages, send emails, send a fax and no one has called back. Are they still in existance? Does anyone know if another dealer where I can get these parts?
Posts: 563 |
dude Get a ram HD from summit excellent customer service and its only 369 dollars. Get the fidanza flywheel from nippon parts out of florida and they will send you the flywheel straight from ohio. Much cheaper also they can get fidanzas for 415 shipped to your door. Spmotorsports price has went up on them. I got my flywheel in three days. I am still waiting on the clutch but ram makes a very good clutch just ask buckshot or terry haines. I have one in my mustang and I love it. I can make the cd player skip on a regular basis.
