sordz Offline OP
so i have been searching for the answer but i will just ask so i get the right one. the autometer oil pressure sending unit goes into the engine underneith the throttle body to the right alittle? there is some type of plug there, just undo it and stick the sender in? is this right? also any tips on installing a air/fuel, and volts guages would help.
thanks
dwh Offline
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=1;t=013607
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
PM me I will help you.
98 GREEN SE
RACTIVE.
75 NOS.
KONIG WHEELS.
ST200 UPPER INTAKE MANIFOLD.
SVT TB.
BOCH +4 PLUGS.
9MM PLUG WIRES.
AUDIOBAHN, ALPINE, PLS2 INSIDE. AUTO METER.
SVT BODY KIT.
SVT GAUGE CLUSTER WITH INDIGLOW GAUGES.
MORE COMING SOON.
