How do I bypass the air sensor in the stock air box? I am going to order a cold air kit from spmotorsports.com soon. I would like to know how to bypass the air sensor.
Green GlowBrite windshield washers
You would never bypass your IAT.
You just find a new place to mount it in the incoming airflow.
2000 SVT #674 - Check it out!
the iat and its placement indeed makes a difference....when i added my monster flow filter it was supposed to be part of a CAI but the intake pipe wouldn't fit my car due to the atx....so i just used the filter and had nowhere to mount the iat....my car ran fine since it was winter anyway but a couple months ago i bit the bullet and put a hole in the sleeve connecting the filter to the maf adaptor and stuck the iat sensor there....car immediate ran soooo much more responsive i was sorry i didn't do it sooner...
i think spmotorsports sells a kit that gives u a place to put the sensor....bat has one too i think
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
