Just some fodder for debate guys... trying get the smarter people on here to use their heads, since I've been thinking about this for a long time, and my brain is just about done for the night.
I know this has been brought up before, but I still don't understand the current arguements against larger pipe sizes (say... somewhere between 2.5 and 3.0 inches).
Many people say that you need high exhaust velocity... that narrow pipes somehow help with scavenging, effectively having the exhaust suck itself out of the combustion chamber, pulse by pulse. While I could see the effect of this in a header, where a pulse from one cylinder could be timed not to collide with the pulse from another as it enters the collector, I don't see how it comes into play after all of the gases have united in a single pipe.
Besides... isn't the potential problem with an extremely high-flow exhaust allowing the intake air charge to exit through the exhaust valves during the overlap period? If we're so, why are we trying to scavenge the cylinders more, when it's this scavenging effect that has the potential to (when taken to the extreme) hurt low-end power drastically and maybe even cause damage.
The other common argument is that gasses cool off as they expand... but what of that? They're going to eventually have to cool off and fight 1 ATM of atmospheric pressure in order to exit your tailpipe no matter what you do. I fail to see the consequences of this situation, or why it would be a problem at low-rpms, when overscavaging and resulting torque loss is what we're trying to prevent, not effect.
So which is it? Is a larger exhaust (albeit one that makes many, many bends on it's way to the rear of the car) so free-flowing that intake air and fuel are getting sucked through the exhaust valves before the cylinder fires? Or is a larger exhaust restrictive enough to ruin your low-end because those cooling exhaust gasses become so incredibly heavy. In which case, would decreasing the length by an amount proportional to the increase in cross-sectional area (keeping overall volume the same) prevent this massive torque loss? Or would you then resort to the opposite argument, claiming that overscavenging is the problem? Do you see how easy it is to talk in circles about this without even realizing it?
(BTW, I don't mean to sound like a know-it-all... I'm just starting to get a feel for this, and I want to understand it better
