I am Canuckian
I am Canuckian
Posts: 4,168 |
Originally posted by Pimp98: Oh yeah,and I've topped mine out,170kmh on the 401. Stupid limiters.
Limiter is @ 184 so you may want to make sure your speedo is reading right.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 63 |
Originally posted by LoCoZsc: I have 130k on my Zetec ATX....added a supercharger 10k ago.
BTW if anybody wants to know.....it is drag limited at 143mph.
The SVT was drag limited (no speed cut off in the computer. If you want to go faster, you just need more HP to overcome drag.
The speed limiter is there to keep you from exceeding the design limit of the tires, btw.
Back to the question, the PO says the engine was rebuilt due to cracked rod at 50K miles. Now has 105K miles. PO also says it is good for an indicated 145 MPH.
Carl
2000 Black CSVT #415
89 SHO (RIP)
75 280z
Posts: 862 |
I saw one with aout 220k miles, it looked like the ATX had gone bad as there wasn't a dent on the car on the oil was clean and ATF was really dirty. Probably on its second tranny or at least a rebuild.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 498 |
my ATX zetec just hit 137,000 today.. everything factory.. even timing belt
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 699 |
289,000 ish, km(180k miles) on the Mystique, original engine/tranny. Someone in the Eastern Canada forum has an SVT with over 300,000km on it.
My Cars
1999 Silver Frost SVT - 80,000km #2603/2760 Aug. 10, 1999.
1996 Mercury Mystique LS V6 MTX - retired @ 323,151km.
1995 Ford Contour V6 MTX-sold @ 214,000km
Posts: 21,653 |
130mph, still pulling. ~115k miles.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 135 |
Wow and I thought my 230,000 km on a 99 was atleast somewhat impressive, apparently not so much, but its still the orig. engine and tranny (ATX) so I guess I'm not doing too badly.
Posts: 759 |
123,000 SVT with 91,000 miles on the replacement engine.
I havent had the bravery to take my contour anything past 125mph because the stock suspension is scary at high speeds.
Now my integra GS-R 137mph not bad for a 4 banger.
E0 #4384 of 6535
Born Jan. 9 1998
My SVT from the ashes
147,466 miles, purchased Nov. 2002 @ 76,559 miles
Posts: 10,015 |
146mph
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 6,106 |
2.5L blew at ~52k miles.. 146mph on the 2.5L
3.0L been running for ~27k miles.. Hit 150mph and still pulled..
It's amazing how much more the 3L pulls on the top end where the 2.5L took FOREVER to get from 130 to 146!!
Mark
2000 Black CSVT
