CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SonofSHO: Originally posted by LoCoZsc: I have 130k on my Zetec ATX....added a supercharger 10k ago.
BTW if anybody wants to know.....it is drag limited at 143mph.
The SVT was drag limited (no speed cut off in the computer. If you want to go faster, you just need more HP to overcome drag.
The speed limiter is there to keep you from exceeding the design limit of the tires, btw.
Back to the question, the PO says the engine was rebuilt due to cracked rod at 50K miles. Now has 105K miles. PO also says it is good for an indicated 145 MPH.
Look at profile....I have a blower.....and no speed limiter.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 63 |
Originally posted by LoCoZsc: Originally posted by SonofSHO: Originally posted by LoCoZsc: I have 130k on my Zetec ATX....added a supercharger 10k ago.
I did read your profile, you are still running out of HP to overcome drag, although with an ATX you may be running out of gear also. I bet some of these FI 3.0 L guys could top 160 if they don't run out of gear.
Carl
2000 Black CSVT #415
89 SHO (RIP)
75 280z
Posts: 21,653 |
Which would be drag limited right? What did he say that you are disagreeing with? And with the ATX you have more gear than a mtx.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 466 |
when my svt was new, my dad did 145mph in it.
98 contour svt
#6473 of 6535
Posts: 7,100 |
Originally posted by SonofSHO: I did read your profile, you are still running out of HP to overcome drag, although with an ATX you may be running out of gear also. I bet some of these FI 3.0 L guys could top 160 if they don't run out of gear.
The posted max for (Buckshot?? IIRC) was a theorhetical 186-ish..
I don't know what makes it theory and not fact, be it gearing or merely room to do it...
Ray
'99 CSVT - Silver #222/276
Posts: 227 |
Originally posted by CSVT985: I havent had the bravery to take my contour anything past 125mph because the stock suspension is scary at high speeds.
I've had mine up to 110 or so and I thought it felt very stable. This was on a straight highway, I wasn't trying to take curves or anything...
98 Contour V6 MTX, T-Red, 150k mi. Pic
SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin
95 F-150
91 Mustang GT
06 Honda Shadow Aero
Posts: 306 |
I have 54,5xx, and I've hit about 135 it gets a little scary up there.
98 CSVT Black
Alpine CDA 7995
Memphis 1000D & Alpine MRV T302
2 Orion 12's
HPP Rear Strut Bar
Posts: 7,100 |
Oh.. re: original post
110,000 Original engine, original tranny..
Ray
Posts: 6,106 |
Originally posted by Kremithefrog: And with the ATX you have more gear than a mtx.
What's the final drive of the ATX? Not sure where you're coming up with this. Also, which MTX are you talking, the Duratec or Zetec final drive?
Mark
2000 Black CSVT
Posts: 7,100 |
Right off the main page..
Transaxle: MTX-75 Final drive: 4.06:1 Gear Ratio Speed (mph) 1st: 3.42 35 2nd: 2.14 56 3rd: 1.45 82 4th: 1.03 117 5th: 0.77 143 (drag limited) Reverse: 3.42
Transaxle: ATX Final drive: 3.92:1 Gear Ratio Speed (mph) 1st: 2.89 42 2nd: 1.57 79 3rd: 1.00 124 4th: 0.70 178 (yeah, right)
Looks like the ATX could have some more gear in it...
Ray
