Page 2 of 2 1 2
#1186246 02/15/05 01:02 AM
Well the one off of my 96 is not a direct bolt on, the only difference between the two is the part that bolts to the tranny. So I swapped the 2 bottom pieces out and it fit fine. The one off of my 96 looks to be a bit more stronger since the rubber part is fully incased in metal.
Originally posted by Davo:
Good work, Dave. You're definitely the #1 interior guy around these parts; always innovating.
Redline Goods ShifterBoots:5% Discount
#1186247 02/15/05 05:02 PM
I broke mine also, got a new bolt for like $5 bucks and replaced it and its good as new.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998 WR Headers GMK CAI Blaupunkt system fiberglass tweeter pods L.E.D. tail lights in the works
#1186248 02/15/05 05:10 PM
Yeah first time I saw that, the CEG'er thought it was supposed to come out like that!
We drilled into the portion still stuck in the trans mount and removed it with an easy-out.
Then ou pulled out the giant mushroom looking metal portion out of the rubber isolator, pitched it in the trash, and replaced it with a large Grade 8.8 bolt of the same thread tt was before and large diamter washer . a $5 fix.
Page 2 of 2 1 2
