Posts: 674 |
As I was giving my SVT a tune up since it had been parked most of the winter, I was cleaning my air filter when I noticed something didn't look right. So WHAT THE F-CK happened here.    No I haven't been racing or getting wheel hop, although the last time I did drive it I do remember hitting a pothole but it didn't seem big enough to do this kind of damage. So my next question is are these universal thru all of the years, cause if so I will just go and take it off of my 96 that I am parting out.
Posts: 1,356 |
 I think it might be different, but im not sure. Im sure someone who knows for sure will chime in...
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 2,542 |
damn
Posts: 715 |
 Wow you/someone did a good job on that. Just my 2 cents, the bolts that are hold the tranny to the motor are probably under a good amount of stress right now, I would put a jack under the tranny to take some stress off. Just an idea. Hope that nothing is broken on the tranny and you'll be able to just put a new mount on with no problems.
Brian W. -------------------- Black 1998 SE 5 speed - TOTALLED
Posts: 3,065 |
Yikes, what the hell is that?
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Breaking of that bolt is pretty common. Not sure if it's unniversal though.
-Aureo
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 1,036 |
That is a broken motor/trans mount. Time to replace it.
dion
98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
Posts: 9,065 |
I know stazi has drilled thru the top and replaced the bolt with a new one. Much cheaper than the dealership alternative. I'll let him chime in. I will do the same when mine breaks.
Posts: 93 |
yea much cheaper. when i broke mine they wantd me to buy the whole assembly and it was like $125. Just put a different bolt in it.
Posts: 685 |
Originally posted by dpa43: As I was giving my SVT a tune up since it had been parked most of the winter, I was cleaning my air filter when I noticed something didn't look right. So WHAT THE F-CK happened here.
exact same thing happened to me...I bought the car about two months ago and went to put in my RU-3530 and saw something looking weird below it (it was the tranny mount aka roll resisitor you have it your hand). I picked it up to see the bolt had snapped just like urs. I soaked the snapped bolt w/ PB Blaster and let it sit over night. Next day i put the snapped end of the screw in a vise and used a huge pipe wrench to grip the "mushroom piece" (you'll know waht i mean if you pull that swiss chees lookin rubber piece off)to get it off. Then went to my local harnware store and bought a 8.8 grade bolt (must be atleast 8 grade or it will snap again SOON). Its a PITA to find the right legnth bolt w/ the right length threads to fit. But trial and error works
I would take it out to tell you the exact length but its way to much of a PITA, but I'll try to help you as much as possible. Just PM me. Like mentioned earlier the whole part is over $100 and you can buy a bolt for a couple bucks. worst comes to worst buy a few diff lengths and use the one that works. you'll be saving ALOT of $.
Justin
98.5 CSVT # 4887 of 6535 (born 2/28/98)
