Posts: 3,562 |
FYI: I'm talking about removing the plastic clip that connects the cable to the secondary linkage, not the electrical clip to the IMRC box.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,152 |
Oh Ok... Can I get to that thing with the UIM on or do I have to take it off??
As long as I run premium I shouldnt ping... And yes I want more power...
Thanks Brad
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 3,562 |
You should be able to reach it, but you might have to remove you intake piping to see what you're doing. It's been so long since I've had secondaries, I can't really remember...
Posts: 7,329 |
Originally posted by bnoon: Originally posted by SVTJOE1: [b]Guys, Is there anyway to make it throw a CEL to get the spark advance?? Disconnect the plastic clip from the secondary actuator. MIL should light up during your first drive. [/b](edit - good man Brad  ) DO NOT disconnect the IMRC box. This will instantly send your car into limp mode. It will even override a chip! Limp mode = flatline advance and fuel cut. (I have graphs for this too  ) To get the CEL you want "P1518" just disconnect the return spring. Rev the engine above 4000rpm. Shut engine off. Start it up and the CEL will be there automatically.
Posts: 3,562 |
Posts: 460 |
Well, I replaced the butterflies with some better screws and some thread lock. I did it, this time, off of the car. I pulled the LIM off and scrubbed it down. It is pretty clean now. When I went to the track with the LIM Butterflies off, I could hardly get out of my own way. Even with all of my mods, I was running 15.9's. That is sad when I ran a 15.2 stock with a K+N Drop-in! Oh well. Maybe this mod would be better in a 3.0L or with a more massaged UIM.
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
Posts: 1,812 |
PO-JAY, did you "optimize" the butterflies? I think that would be a good idea for anyone not willing to lose low end power.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 583 |
Po PO I don't know exactly what you did but I love my car with no secondary butterflies as apposed to with. My car pulls just as much low as it did before if not more but top end is fantastic.
Thanks, Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 1,251 |
Run .002 - IMRC siezed shut Run .003 - IMRC pinned open Run .004 - IMRC working. Does this help? (non-SVT, 2.5L) Mods: ST200 UIM, optimized TB (SVT), KKM, ram-air (fed with fan), 2.5" exhaust.
Posts: 1,847 |
That dyno chart makes me think that it would be better to open the secondaries below the current 3400 RPMs. The crossover at 3250 indicates that you will get a benefit up to this RPM if you open them sooner. Too bad you don't have numbers down to about 1500 RPMS, as that would give an indication of just where to open them. I'd like to know so I can get a chip custom programmed...
I'd also like to see a chart with cracked secondaries.
95 Contour SE ATX V6 "Cracked" Secondaries DMD Installed SVT Brakes
