Page 2 of 3 1 2 3
Anybody got pics of Speed Bleeders installed ?
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
-HWCM- Offline OP
Originally posted by Rara:
quick question for you guys that have done a full fluid flush recently, how much fluid did it take you? I'm doing mine tonight and gotta pick up some fluid on the way home.
I used a Quart,I guess its a quart its the large bottle on the shelf.Had exactly enough! laugh
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
-HWCM- Offline OP
There is nothing special about them,they look EXACTLY like regular bleeder screws.Even out of the package other than the hole in the bottom I couldnt tell a difference.Unless you pay extra for the polished ones. :rolleyes:
Howard
June mods:
Originally posted by -HWCM-:
[b]quick question for you guys that have done a full fluid flush recently, how much fluid did it take you? I'm doing mine tonight and gotta pick up some fluid on the way home.
I used a Quart,I guess its a quart its the large bottle on the shelf.Had exactly enough! laugh [/b]
If the old fluid is really raunchy you may need about 1 1/2 quarts. If you change it every year, you don't need quite a full quart.
Jim Johnson
98 SVT
Administrator
Administrator
well, unfortunately, I didn't get a chance to do it tonight, since I had to go back into work (grrr) but I went ahead and picked up some brake fluid tonight. I got 4 quarts . . . but before anyone laughs or says anything, remember, I gotta do my Cobra too, and the fluid in it is prolly 8 years and 83k miles old (looks like ink, ewwww)
the contour isn't quite 2 years old yet, it mostly just needs bleeding, but since I have abused my brakes over the car's short life, I figured a full flush would be good.
It's all about balance.
bcphillips@peoplepc.com
I used just under 2 qts of brake fluid. I did the clutch hydraulics as well.
Autozone carries the speed bleeders for the rears (all), and early SVT fronts. Since both are the same size.
~$8 for a pair.
2000 SVT #674 - Check it out!
You'll need two quarts exactly, it you're replacing the nasty, gucky stuff that's been sitffling my braking since I bought the car 5 years ago. Younger cars with more frequent flushes won't need as much.
'98 Black SVT #651 of 6535
KKM Intake (Miks Heat Shield in Winters/Drop-in K&N Summers), SHO Y-Pipe, and Bassani Exhaust.
Eibach Pro-Kit, Koni Struts, and Enkei RS5's with BFG-KDWs (215/45-ZR17)
BAER 13" big brake kit+rear baer rotors all zinc washed, cross-drilled and slotted (Greenstuff binding rears)
Kenwood head unit with Infinity reference speakers+1 8" Bazooka Tube fed by two MTX Blue Thunder amps.
Hella Stage II HIDS from hids4less.com.
Recaro Sport Seats trimmed in supple black leather.
And Zymol wax to keep it squeaky clean.
W
W
I just bought the single big bottle of valvoline synthetic and that was just about right to flush all of the lines. I was experiencing brake fade as well, and I changed the fluid. Cleared it right up. The fluid was a little over 2 years old. I usually try to change it once a year though.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
-HWCM- Offline OP
warmonger[/b]
DITTO!
Howard
June mods:
Yeah, I plan on flushing the brakes soon. Never done it before, so it will be an experience!
98 Black Mystique; Duratec/ATX
"Mystique, the luxury SVT"
P.S. This is what part of the alphabet would look like if the letters Q and R were omitted...
Page 2 of 3 1 2 3
