Page 2 of 2 1 2
#118421 05/08/02 11:35 AM
MaVRoCK Offline OP
2 questions left:
What's the conical Part No.? (I wanna make sure I get the right one if ordering online)
and
Is the conical trashed after getting wet from rain or whatever?
99 Black SE Sport ATX
Running on E1 SVT rims with Dunlop rubber
Pioneer DEH-P3100 CD receiver (2 channels of the amp blown, officially declared dead)
Pioneer DEH-P440 CD receiver
Pioneer TS-6865 6x8's in the front
Pioneer TS-6867 6x8's in the rear
Pioneer TS-WX121 Sub with a Pioneer GM352 amp feeding it
#118422 05/08/02 01:19 PM
It'd be pretty tough to get the filter wet with rain and what not (unless you have a gigantic hole in your hood). If it does "happen" to get wet, just let it dry out a bit and clean/re-oil as you feel necessary. As to the part number, I'm not sure (but you can check on their web site).
'99 Contour SE V6 w/MTX (Black Clearcoat)
'02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
#118423 05/10/02 09:20 PM
Normally, I would just read this and chuckle. However, I'll respond to two points in this post.
1) Water will not trash a K&N air filter. When you clean a K&N air filter, you have to rinse it off and dry it. [Besides, how do you get it that wet while it's installed, anyway?]
2) If the sensor you are referring to is the IAT sensor (it looks like a plastic loop around a little plastic bead with two wires coming out of it), you can just use a wire tie to keep it from flopping around while you look for a way to install it into the filtered air stream. I did that until I had time to make a hole in my air filter base on my car (I used the bottom half of an SVT 'airbox' as an MAF adapter plate). Since you are getting a CEL you may want to reset the computer memory by pulling the fuses (#4 & #11) in the fuse box next to the battery. You only need to leave the fuses out for a few minutes (you can disconnect the battery instead, but then you will need to reprogram the radio presets and reset the clock).
HTH
Mike
cool
1996 SE MTX, Desert Violet
Blaupunkt Munchen, Dunlop
Sport 5000s, Ray
McNairy's THFix, custom air filter,
Magnecor wires,
Redline D4 tranny cocktail,
9005 lo-beams
SVT-size front rotors, EBC Greenstuff pads all around
#118424 05/13/02 04:08 AM
Don't go and get a friggin' K&N filter. If you want power go to heir intake kit. I did that and all of sensors have a place to go. The CEL is on but fuggit. It works damn well and looks nice too. cool
Eurolite clear side markers
Eurolite Xenon bulbs
Weapon-R cool air intake
Page 2 of 2 1 2
