Posts: 7,100 |
You guys are FAILING to see the point... the MAX line on an SVT is 5.8Qts... THAT IS NOT ENOUGH.... For those that doubt, please reference previous post from Demon stating the SAME thing as this: even 12 or 16 oz is a HUGE amount when the pan is literally RUNNING DRY. You may not want to THINK that half a quart of oil will make a difference, but I will be the one to sit here and help diagnose your knocking sound, or your engine dying... and I will continue to help you, even if you do so choose to ignore READILY ACCEPTED recommendations, and KNOWN ways to avoid problems. Run more than the manual states.. 'Nuff said.. (haha)  Ray
'99 CSVT - Silver #222/276
Posts: 685 |
Originally posted by Ray: You guys are FAILING to see the point... the MAX line on an SVT is 5.8Qts... THAT IS NOT ENOUGH....
'Nuff said.. (haha)
 Ray
Im not failing to see the point. Those that have replied about amounts (Stazi and some others IIRC) said to run 6 -6.5 qts in the SVT. Stazi said he "runs 6 quarts all the time" The manual says the capasity is 5.8 or roughly 6. That being said you are already at up to the max line "the recommended 6qts" when you change your oil. I highyl doubt people pour 5.8 qrts and do not put ALL 6 qts in when they change the oil. The question was wether or not to add the extra .5qrt or not to be safer. If i were missing the point I would have far less than 6 quarts in the engine when everyone is saying to run at "6.........to 6.5".
The misconception here is where ppl are throwing in the "6 to 6.5" The max line is already 6. So simply state "run 6.5 quarts" then there would be no misconception.
Justin
98.5 CSVT # 4887 of 6535 (born 2/28/98)
Posts: 7,100 |
Oil change locations add 5 qts.. period...(unless otherwise told) IF you (the normal non-enthusiast, not YOU particularly...)think to check the level you would add oil until you hit MAX... which would be 5.8... not 6..
even AT 6... you are still on the bottom edge of what isn't even a TRULY safe level... you can STILL run dry at 6.. (hell even 6.5)
You wanna run 5.8.. go for it.. .2qts MAKES A DIFFERENCE... you wanna go ahead and run 6... go for that, too.. but I am telling you.... 6.5 makes a further difference than 6. even 6.5 is not totally safe.. there is just too big of a flaw to overcome with overfilling it with oil..
get an accusump (or equiv) and use it.. 5.8.. 6...6.5... It really doesn't matter if you want to run more or less.. you still need an accusump to fully protect you.
Agreed?
Ray
Posts: 4,141 |
Originally posted by Stazi: In fact think it was SHO Shop that made a pan with a window in it
actually i think it was the Mumm brothers.
http://www.mummbrothers.com/T2_Stuff/T2Main.htm
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 685 |
agreed ...the accusump will help the most regardless of 6 or 6.5 etc.. I haven't scoped out the engine bay VERY hard to see if the previous owner put one in, but, he seemed like a pretty knowledagble and perfromance forward type of owner. (had the resonators removed, pro flow MAF, etc. etc.) Guesss I'll have to grab one if there isn;t one. It looks like there is room by the washer fill. Seems to be a good deal of fender/wheel well metal to put it there. What does everyone think?
Also is ther only one place that the hook up feed for an accusump goes in at? Meaning if i look for a plug and nothing is hooked up to it its oviuos there is no accusump.
Justin
Posts: 837 |
From BAT Catalog: RE Accusump oil lines This supplies oil through hose to the oil filter location to an adaptor mounted between the block and the filter. This is the oil input to the engine on non oil cooler equipped cars (pictured). For oil cooler equipped cars (most SVT's) we can supply components to run the oil supply directly to one of the engine block oil galleys.Is placing the oil supply directly to one of the galleys going to solve the problem of the oil pan running dry? How will the oil be equally distributed? (Forgive my potential ignorance as I have yet to dismantle a duratec  ) Will an oil return line be needed, or will the one line be dual purpose? How hard is it to get clean oil into (and dirty oil out of) the Accusump? Do you have to pump compressed air into the Accusump at each oil change so that it stays under pressure? Thanks! Bridge
CSVT
Feels Like Heaven
Goes Like Hell
Profile
Posts: 638 |
An oil accumulator (Moroso or Accusump both are well known brands is racing) is a hydro-pnuematic cylinder. Ok, so what does that mean? These accumulators are sealed aluminum tubes with an o-ring sealed piston inside. On one side of the piston is a pressurized air chamber, on the other oil. The oil compartment is connected to the engine through one hose. During initial startup additional oil is added into the system with the accumulator valve open, the oiling system pressuizes and fills the accumulator's oil chamber, the piston forces the air in the air chamber to condense, thusly pressurizing the for mentioned air chamber. Now, if the engine's oiling system looses pressure, resistance on the accumulator piston falls, which now allows the pressurized air chamber to push the piston thusly pushing the oil from the accumulator into the engine's oiling system. When the oil pick-up in the pan is once again submerged in enough oil to maintain pressure in the system, the oiling system pressure over comes the air-pressure resistance in the accumulator and this whole process begins again.
I hope this clarifies the funtion. The accumulator system is dynamic, fluctuating pressures result in a constant exchange of oil in and out of the accumulator (to some degree).
One thing to remember is to always shut the valve before turning off the car.
Getting oil out (say for an oil change) is easy, you just open the valve with the motor off; no positive pressure on the accumulator results in pressure coming out of the accumulator.
As for the equal distribution through the oil galley, this is my Theory. Assume oil-pump pressure drops, accumulator oil begins to enter the system, however since there are no check balls in the galleys, this oil will travel any direction it can. However, since the pump is still spinning, oil can only back feed as far as the pump, because the pump is still working to pump oil the correct direction. However, oil is not being fed out of the pump, but it also can not travel backward through the pump so, this path is neutral. Therefore, oil can only flow through the galleys the proper direction, because only the proper flow direction allows for flow, and if the oil is flowing in it's proper direction, the oil will distribute itself exactally as it would if the pump were supplying. Once again this is only MY Theory on how the accumulator maintains proper flow and protection when attached to an oil galley
*Note* When using the spacer block thingy that the BAT Accusump can be equiped with (for non oil-cooler cars), the oil flow is directional due to the inclusion of one-way check-balls.
It is always wise to check the accumulator's air pressure, the same as it is wise to check your oil level. Things being ideal, neither your oil level or accumulator pressure will need a top-up, but this is the real world, so keep tabs on it; it should easily hold it's pressure from one oil change to the next.
I'm not going to say that it is not possible to fit an accumulator by the coolant resvoir, BUT there is no way mine would fit there. 1.5 qt Moroso accumulator = 10" long 4.5" in diameter, PLUS there is ~2.5" of additional space needed at one end for the air chamber pressure gauge and valve stem, and another 3-4" on the other end for the oil control valve (on/off). You could remove the gauge to save an inch of length, and the valve does not need to be mounted directly to the accumulator, it can be remote and connected by hoses.
Honestly, I found 3 places that my accumulator fits up front: 1. the battery tray (if you want your battery in your trunk) 2. Mounted to the under-side of the right inner fender (this is where the washer resevoir is mounted, so using this location would require removing the washer resevoir and sprayer pump) 3. Under the cowl panel where the cabin filter is. This requires removing the cabin filter assembly, 2 bolts, it comes out easy. This is where mine is, I care less about having a cabin filter than a clean windshield, besides the filter needed to be replaced and I didn't feel like it.
87 Mustang GT 5.0L TURBO
Posts: 4,140 |
The only valve is on the accumulator, right? So you shut the valve when? Before an oil change? You can't mean every time you drive, can you?
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
No way. I have an electronic solenoid on mine which is powered off of the iginition circuit. Turn the car to the on position, the valve opens and you are good to go. When I start the car, I usually turn the key to ON, wait until all dash lights turn off, this is basically preoiling the system, and then turn the car over. I then wait 15-30 seconds, usually seat belt and sunglass time, blip the motor once to help the trans lube up and away I go.
Oil changes are cake. Warm the car up usual, and get the car up on ramps. Once at temp, shut the car off and dump the oil. Once the oil is out of the pan, turn the car to ON and another 3 quarts from the AccuSump come out, due to the lack of pressure.
Once completed and ready to fill, put in 7 quarts. The car will be overfilled with oil, but no worries as the AccuSump will suck up the oil it requires. I then put in another quart and check the dipstick. I then add until a 1/4 inch over the max line on the dipstick, about 9 quarts.
I currently have my AccuSump installed where the battery was, but I will be moving it under the wiper cowl, already mocked and ready to go, just too cold out! I still need to figure out how to get the oil line out, without cutting a hole.
Yes, its worth it. I saw my oil pressure drop to 25psi on a hard turn (well, the ex saw it) and then it went back up to normal as the AccuSump dumped its load. Saved my motor right there.
Chris
NJ
98.5 SVT Silver Frost
Posts: 638 |
Originally posted by Shaggy: I currently have my AccuSump installed where the battery was, but I will be moving it under the wiper cowl, already mocked and ready to go, just too cold out! I still need to figure out how to get the oil line out, without cutting a hole.
There is a hole in the corner where the everything comes together (under the hood hinge) that seems to open into the inner fender. If you remove the wheel liner, the hose should be able to be snaked out that hole, along the inner fender, and to the front where it can easily enter the engine bay with the a/c lines. Then with the wheel liner back in place, everything is good and hidden. (The hole exists, but like you say, it's cold out, so I haven't fed line yet, this is what looks like will work.)
