Posts: 638 |
For those of you that have an oil accumulator on your car, where did you mount it??
87 Mustang GT 5.0L TURBO
Posts: 344 |
Ive seen people relocate the battery to the trunk leaving plenty of room for the accumulator.
95 V6 5SPD.
Shaved bumpers,antenna,trunk lock and 1/4 extensions
MIDNIGHT RED.
Posts: 2,676 |
Had mine in the trunk....
note: I got the car that way.
Posts: 9,602 |
DAMN isn't that a lot of oil line to feed! How bad is the pressure drop?
I agree mounting it where the battery "was" is a good location.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 638 |
unfortunately I still have the battery up front. I'll have to keep looking.
Posts: 9,602 |
A 1 quart accumulator may fit below it???
If you are talking about a bigger unit then moving the battery is by far the best choice. There just is not much room otherwise.
2000 SVT #674
Posts: 2,676 |
Originally posted by DemonSVT: Originally posted by Wien_Sean: Had mine in the trunk....
It's wasn't so bad, it was a 3qrt one. Agreed it wasn't the best place but in corners it would catch the crank case pressure drop real quickly.
Posts: 5,143 |
not to steal the thread, but what exactly does an Oil Accumulator do?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 5,621 |
Originally posted by ALIAS Jerk: not to steal the thread, but what exactly does an Oil Accumulator do?
Oil Accumulator/Oil Separator:
"This oil separator kit reduces detonation, oil burning and deposits on the valves by removing oil drawn through the PCV system before it can contaminate the intake charge. Excess crankcase pressure (sometimes known as "blow-by") is vented from the crankcase through the PCV system, where it is drawn into the intake manifold and returned by the engine. This re-circulated air contains aerated oil from the crankcase which is burned by the engine. Supercharged, nitrous boosted and high mileage engines often draw excessive amounts of oil into the engine through the PCV system. The Steeda oil separator plugs into the PCV hose between the PCV valve and the intake manifold and removes aerated oil from the re-circulated air and collects it in a tube that can be drained and recycled."
Posts: 1,580 |
Originally posted by R_G: Originally posted by ALIAS Jerk: not to steal the thread, but what exactly does an Oil Accumulator do?
Umm, no. Accusump
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
