bohdi Offline OP
I wasn't sure where else to post this....a search yielded precisely nothing
My trunk will not release from the remote, only from the lever inside the vehicle... What commonly causes it to fail? Any ideas? Fuse? Solenoid?
98 C-SVT
I think it's the solenoid, and it's a very common failure. Mine's been out for a couple of years, and I've just not squeezed out the money to fix it.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
bohdi -
Here's the fix procedure:
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=407409&Forum=trouble&Words=trunk%20release&Match=And&Searchpage=3&Limit=25&Old=allposts&Main=407409&Search=true#Post407409
How to find it using "search":
- Choose "Troubleshooting" under "Forum or Category to search"
- Enter "trunk release" under "Words to search for"
- Use "And" under "Search options" ***THIS IS IMPORTANT***
- Use "All posts" under "Date range"
1995 Contour GL V6 ATX T/C 1986 Mustang GT 5.0 2000 Windstar LX
bohdi Offline OP
AH HA! I can't believe I've never noticed the troubleshooting forum... This isn't my primary message board (that sounds so pathetic doesn't it), so I usually just skim over everything rather quickly...
Anyhow, thanks for the link phil.
-Jason
98 C-SVT
Mine only fails when it's cold out.....wonder if the dis-assemble and cleaning would help it?
'99 Sport TropicGreen,Duratec, SVT exhaust, Brembo rotors, Ceramic pads, K&N filters(oil & air), Alpine CDM7874, Polk DB570 speakers front and rear. Fog light mod. 50% Formula One tint.
