Posts: 4,714 |
Originally posted by getlucky151: Should you use friction modifier with Redline MTL?
No.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 2,033 |
Originally posted by hetfield: Originally posted by getlucky151: Should you use friction modifier with Redline MTL?
No.
Got it, see thats all the answer I needed, not some 1000 word essay on how people wine.
Posts: 4,149 |
Originally posted by getlucky151: Got it, see thats all the answer I needed, not some 1000 word essay on how people wine.
The sad part is that you posted your question at 4:14 EST and had you actually SEARCHED you could've had the answer by 4:15. THAT is worth a
-- 1999 SVT #220 --
Posts: 2,469 |
Originally posted by ALIAS Jerk: Originally posted by Daves95Contour: but do i need it??
as stazi said... yes. Unless you want a grenaded Tranny down the road.
Please explain how not having friction mod. Is gonna blow up a tranny
Posts: 248 |
Thats what im saying. How is not putting in the friction moddifier going to ruin the tranny. I bet a different smoother feeling tranny if you put it in but ruining it from not putting it in???
Midnight Red 95 Contour SE 5 speed, fully loaded. kkm M.A.F. adapter w/ K&N ru-3530, single Magnaflow muffler w/ no res. 2.25" custom catback exhaust, grafite painted stock 95 SE rims on bfgoodrich touring T/A's, 35% window tint around.
Posts: 2,353 |
Originally posted by dubkatz: Originally posted by ALIAS Jerk: Originally posted by Daves95Contour: but do i need it??
Didn't you know that friction mod is the only thing that keeps transmissions together! I mean common, everyone knows that. Geez, I bet you don't even fill your blinker fluid tank!
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 167 |
Can you give us people who don't know any better a little more scientific explanation than that?
Posts: 1,176 |
Posts: 1,325 |
I run a pump from my tranny to my blinker fluid resovoir, that way I also get my friction modifier to help prolong the life of my blinker bearings. They blink much smoother with the FM in them
Friction modifier helps your MTX shift smoother - that's it, nothing else.
Your tranny will not blow up or otherwise destruct if you don't use it, but it will probably shift better with it.
The 95 manual IIRC called out to use it, but on later cars it was no longer recommended in the manual, but enterprising CEGRs used it nayway and found it helped. The original P/N was deleted, the new F/M everyone uses is actually listed as a differential fluid product that is probably the same thing as the earlier product with a new P/N. It smells like cat piss, don't get it on you!
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 9 |
The "friction modifyer" only applies to manual transmissions, correct?
