Page 2 of 3 1 2 3
Yes, i would love to see pics of this millennium SVT!!
9
9
yeah let me see pics cause i am selling my 18s and picking up the same 19s on spmotorsports
I
I
I'm sure those 19s do wonders for your track times!
9
no they dont....that's why you keep the stockies....Doh!!!(Homer)
1999 Cougar V6 MTX SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Millenium = 2000, get it?
He thinks he's clever.
Yes, i get it... I just want to see pics... sounds pretty sexy!
9
9
Hey i am thinking of gettting those 19s i have my car dropped on H&R springs you think if I put those 19s on will it raise it to much cause i dont want it to look like a 4 by 4 or will the H&Rs look good anough
If you use the proper tire for 19's (+3) the tire diameter is roughly the same and the ride height basically will not change enough to really notice.
+0: 215/50-16 = ~24.3" Dia. (Stock)
+1: 215/45-17 = ~24.7" Dia.
+2: 215/40-18 = ~24.7" Dia.
+3: 215/35-19 = ~24.9" Dia.
215/35-19 will be ~1/2" taller then the stock 215/50-16 depending on the tire manufacturer that is. Not hardly enough to notice and definitely not going to make your car look lifted
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
just all hottness
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
I think you might want to compensate for the additional height by purchasing the suspension that drops the most without compromising ride quality. H & R rides very good (my dad has them on his 99' VW Passat, but you may find a lower ride height with Intrax. Evaluate your options and make an ultimate decision.
I am running 19's with 215/35/19 tires, and the decreased tire flex makes the car sit much higher (a 50 series tire on a 16" rim with the same overall diameter of a 35 series tire on a 19 inch rim will sit the car lower since the 50 series tire has more "give" or "flex" thus making the car sit lower.) Not trying to get scientific, but those are the basic principles of ride height change when you plus-size.
I was able to compensate for this by raising or lowering my ground control coilovers. There are many coil over options out there to choose from, but they get more expensive when sold as a set (ex: Koni coil-overs). If you want to keep things simple, stock struts with Intrax springs should do the trick. Let us know how it goes...
XL
Page 2 of 3 1 2 3
Moderated by  1314_dup1
