Posts: 9,602 |
Originally posted by Stazi: Are these better than silverstars, or is it just a fancy of yours?
Phillips Premiums are better then silverstars. Well much better lumens output though a bit yellower since it's not filtering the spectrum.
If I remember reading correctly the new bulbs (being talked about) are supposed to be "whiter" and brighter.
I just put a set of Phillips Premium ultra blues in the wife's Z24. (rated 4000k)
The Z24 SUCKS for headlight illumination but these bulbs at least doubled the output and it's a clean white light. It had Silvania 9007XV's in it before.
Phillips makes a quality product.
I will look into their bulbs when mine go out. (running plasma bulbs (4000K) and they're decent)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,867 |
Originally posted by TommySVT: Originally posted by RogerB: Yes.
Well, the Osram Silverstars are another story, but you have to get those from an overseas source ($$$). They slightly edged out the VisionPlus in an independent test. (See Plus30 Test and Plus 50 Test. )
Do not confuse Osram Silverstars with the Sylvania version sold here in North America. The US Silverstars are very "bright" but also have a blue filter to make them appear more "white." Critical to the fashion concious, but useless or even detrimental in terms of lighting performance, esp. in bad weather. Blue light scatters, causing glare. (Ever wonder why the sky is blue?)
Don't rely on the "deer in the headlights" test, either. Whiter lights appear brighter when you stare into them, but that's again because of glare.
The test that matters is light on the road at a set distance out front of you. In that test, clear bulbs win.
Your link for the +30 and +50 are the same exact link.
And I just ordered a set of the 9005 Visionplus' bulbs.
So it is. That site is kind of wierd. I had to "register" to see the other product tests.
Well, most of the text is the same, except for the model descriptions.
____________________________________________________
Osram Silverstar Rating: ***** Price: �£16.37 (mail order)
Type: Plus 50 per cent
Beam: 96.9
The flagship bulb in Osram's range, the Silverstar's 75m figure was only a fraction better than that of arch-rival Philips (right), but it performed significantly better at 50m. Add a price advantage, and the Osram's plus 50 per cent competitor is our Best Buy. ________________________________________________________
Philips VisionPlus Rating: **** Price: �£19.98 (mail order)
Beam: 95.1
It's behind Osram's finest, but Philips' top-of-the-range option is a superb bulb which performed comfortably ahead of the plus 30 per cent premium versions. You just cannot ignore that performance, which is why the VisionPlus merits our Recommended award. ________________________________________________________
It's also interesting to read their product test notes on their "standard" bulbs. They threw in a bunch of "blue" bulbs, including PIAA Hyperwhites, and they all performed worse than the standard halogens.
Function before fashion.
'96 Contour SE
Posts: 3,867 |
I haven't read that. For sure, it's a clear bulb with no "white" or "bright" hype.
Here's the Philips lit:
VisionPlus If you want maximum improvement in nighttime driving safety, choose VisionPlus enhanced safety headlamp bulbs. With a beam that�s up to 50 feet longer than conventional bulbs, VisionPlus gives you more time to avoid sudden hazards. VisionPlus gives you the most light on the road of any Halogen replacement bulb.
As we age, we require more light to see safely at night. In fact, our night vision begins to degrade significantly as early as age 45.
VisionPlus bulbs are perfect for anyone who wants to make their nighttime driving as safe and comfortable as possible, especially the millions of older motorists on the road today.
Available in: 9003, 9004, 9005, 9006, 9007 and H7
'96 Contour SE
Posts: 363 |
I have had the VP's in my Jetta for quite some time now. Really pleased with them. Had them for about 2 years now ...
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 1,881 |
I received my VisionPlus bulbs yesterday, and the bulbs are not in their proper packaging sockets. One bulb is wedged in the corner and the other is flopping around. I hope it's ok to install.
1998 T-Red SVT #957
Born 5/14/1997
Posts: 2,033 |
Are these supposed to look like imitation HIDs...
Posts: 4,051 |
Originally posted by weasel: I have had the VP's in my Jetta for quite some time now. Really pleased with them. Had them for about 2 years now ...
2 years? Damn, my bulbs usually last about 6 months.
I've gone from cheap to good bulbs and all last just as long. I gave up.
Posts: 4,051 |
Does anyone have any pictures of them installed on any car? It doesn't have to be a Contique. I searched online and can't find any pics.
Posts: 3,867 |
Originally posted by getlucky151: Are these supposed to look like imitation HIDs...
'96 Contour SE
