Posts: 143 |
I was just curious if any of you techies out there could explain to me what exactly goes on when one "torques" their engine. I was just curious why the engine makes a sound when torqued and what is making the sound and why it's bad to do it do an engine. Thanks a bunch for anyone that can help out.
David
The greatest stealth car ever... CSVT
1998 2.5L V6 MTX
KKM intake with BAT pipe
Magnaflow resonator
other Audio enhancements
Posts: 10,015 |
AND
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,220 |
Maybe you could find a sentence you saw it used wher eyou didn't know what they meant. That would make it a lot easier to explain.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 21,197 |
Originally posted by sigma: Maybe you could find a sentence you saw it used wher eyou didn't know what they meant. That would make it a lot easier to explain.
Translation: Maybe you could copy and paste the info you gathered this information from. Holy F! What happened to our school system?
-'96 SE MTX 3L
Posts: 7,117 |
Originally posted by todras: Holy F! What happened to our school system?
Posts: 37 |
Originally posted by BCSVT: I was just curious if any of you techies out there could explain to me what exactly goes on when one "torques" their engine. I was just curious why the engine makes a sound when torqued and what is making the sound and why it's bad to do it do an engine. Thanks a bunch for anyone that can help out.
Has anyone come up with an answer to this question yet? I'm also curious.
What is it to torque an engine?
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Chris
NJ
98.5 SVT Silver Frost
Posts: 5,345 |
David
Do you mean brake torquing? Like what airplanes do at the end of the runway before rolling for take-off? Brake on while the engine is on full revs.
The things which I can see going wrong are, brake wear or engine wear (the groan or moan sound) from higher revs. Well, maybe not brake wear since the wheels are not turning (the pads might fall off though ).
"Brake Torquing A procedure generally used in performance tests to improve the off-the-line acceleration of a car equipped with an automatic transmission. It is executed by firmly depressing the brake with the left foot, applying the throttle with the car in gear to increase engine rpm, then releasing the brakes. Brake torquing is particularly effective with turbo charged cars because it helps overcome turbo lag."
Unless yours is a turbo CSVT or ATX SVT , you probably don't want to have anything to do with brake torquing.
1996 V6 ATX 96K miles
Posts: 37 |
I heard someone say that u torque the engine when the rpms are too low. say for instance you're driving in 5th gear and the rpms are at 1500.
Is that something that anyone is familiar with? i just didn't have a clue what the guy was talking about so i wanted to see if you guys know about this.
