Posts: 27 |
I am waiting for my engineer to free up the time to specify the material and finish the drawing. I have two suppliers waiting to bid the job, so I do not think manufacturing the bar will be the issue. Race season is just around the corner and we have two hot C5 projects in the shop that are taking up 95% of Dennis' time.
My manager Rick Myers and I understand that this is an important product with good community interest. We have not forgotten about you or the 24mm bar, but our resources are a bit thin at the moment. I will continue to persue this unless I hear that Stazi and his contact come through. Of course if Stazi already has the material spec and or a CAD drawing, I would be willing to work on compenstaion for his investment in this product.
Maxwell Church
Nemo Malus Felix
ATI Performance Engineering
47199 Cartier Drive
Wixom MI 48393
248*848*9200 ext 131
248*894*2219 direct
Posts: 7,117 |
Originally posted by MaxwellChurch: Of course if Stazi already has the material spec and or a CAD drawing, I would be willing to work on compenstaion for his investment in this product.
I'm tellin' ya, Max is a straight-up good guy, just like Stazi... I hope the two can pull it all together & perhaps collaborate on a few more things in the future.
Posts: 10,015 |
AAM will not release the print. But if you PM me I can give you the specs on the material/size. Essentially I copied the EXACT same design, but optimised the tube size and material to increase the torsional stiffness of the bar. Hence, if you have a stock sway bar you're set. No funny changes where made. Geometry is identical. The center-line of the stock bar is the same as the ceterline of the Aussie bar. Also the distance from the endlink hole to the centerline of the body of the bar is the same. Get my drift?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 7,117 |
In the interest of making this happen, I will donate my stock SE bar. I'll be installing a BAT 21mm this weekend, so the stocker belongs to you guys if it will do as a template.
Posts: 706 |
material spec
torsional stiffness
I just love seeing words like this used in a group buy. :P
E1
1999 Cougar - Supercharged 3L
1992 Talon TSi - AWD Turbo
1992 Eclipse GSX - AWD Turbo
Posts: 5,621 |
Originally posted by EternalOne: Quote:
material spec
torsional stiffness
E1
Posts: 1,336 |
Updated List:
1) goalcoach - CEG 2) FastCougar - NECO 3) lbizboy - NECO 4) Pyro81 - NECO 5) qkilobyteq - NECO 6) EternalOne - NECO 7) vodfan - NECO 8) mont - NECO 9) predator - NECO 10) aircougar - NECO 11) getlucky151 - CEG 12) WildChild - CEG 13) Mkingracing - CEG (questionable ... in or out???) 14) Russell-3L - CEG 15) SvtEdwardo420 - CEG 16) Aspire - CEG 17) Titan - CEG 18) BSOELMAN - CEG 19) R_G - CEG 20) RawBurt - CEG (questionable) 21) zakatak - CEG 22) morbid - CEG 23) Rance - CEG 24) tropictour - CEG 25) tour96se - CEG 26) zgendron - CEG 27) NVSVT (SVT) - CEG 28) NVSVT (SE) - CEG 29) DaddyPhatSacks - CEG 30) owen_SVT - CEG 31) 99contourdriver - CEG 32) 04marauder - CEG 33) jaged - NECO 34) svt4svt - CEG 35) Blackwidowsvtt - CEG 36) bensenvill - NECO 37) Kokopellian - CEG 38) svttour - CEG 39) bigMoneyRacing - CEG 40) cvsmightymouse24 - NECO (questionable) 41) 303GreenDestiny - CEG 42) frodog31 - CEG (questionable) 43) topjoe - NECO 44) Bennett9000 - NECO 45) Nick98CSVT - CEG (questionable) 46) LancasterSVT - CEG 47) Res - NECO 48) JaxCougar - NECO 49) Bridge - CEG 50) ButtonPuncher - CEG 51) Christian - CEG (questionable) 52) Jeffs2000BlkSVT - CEG 53) Jorgen - NECO 54) Viss1 - CEG 55) tnkgurl - NECO 56) 2 guard - CEG 57) SVTatGT - CEG 58) COUGAR99 - CEG 59) johnny hennessy - CEG 60) 99Elimin8r - NECO 61) KingpinSVT - CEG (questionable) 62) greenlacougar - NECO 63) SHOgoFast - CEG 64) akronstreetracer - NECO 65) maddbeefer - NECO 66) SVTLAY - CEG 67) BCkat - NECO 68) RodneyBur - NECO 69) FrostCougar - NECO 70) fordrule - NECO 71) 99svtContourMan - CEG 72) VanCityKitty - NECO 73) GForceAuto - NECO 74) 98_HO_Contour - CEG (questionable) 75)
Posts: 193 |
i would like to get in on this.............
david la vista, ne
99 SVT Black/Midnight
1462 out 2760
Posts: 1,336 |
Updated List:
1) goalcoach - CEG 2) FastCougar - NECO 3) lbizboy - NECO 4) Pyro81 - NECO 5) qkilobyteq - NECO 6) EternalOne - NECO 7) vodfan - NECO 8) mont - NECO 9) predator - NECO 10) aircougar - NECO 11) getlucky151 - CEG 12) WildChild - CEG 13) Mkingracing - CEG (questionable ... in or out???) 14) Russell-3L - CEG 15) SvtEdwardo420 - CEG 16) Aspire - CEG 17) Titan - CEG 18) BSOELMAN - CEG 19) R_G - CEG 20) RawBurt - CEG (questionable) 21) zakatak - CEG 22) morbid - CEG 23) Rance - CEG 24) tropictour - CEG 25) tour96se - CEG 26) zgendron - CEG 27) NVSVT (SVT) - CEG 28) NVSVT (SE) - CEG 29) DaddyPhatSacks - CEG 30) owen_SVT - CEG 31) 99contourdriver - CEG 32) 04marauder - CEG 33) jaged - NECO 34) svt4svt - CEG 35) Blackwidowsvtt - CEG 36) bensenvill - NECO 37) Kokopellian - CEG 38) svttour - CEG 39) bigMoneyRacing - CEG 40) cvsmightymouse24 - NECO (questionable) 41) 303GreenDestiny - CEG 42) frodog31 - CEG (questionable) 43) topjoe - NECO 44) Bennett9000 - NECO 45) Nick98CSVT - CEG (questionable) 46) LancasterSVT - CEG 47) Res - NECO 48) JaxCougar - NECO 49) Bridge - CEG 50) ButtonPuncher - CEG 51) Christian - CEG (questionable) 52) Jeffs2000BlkSVT - CEG 53) Jorgen - NECO 54) Viss1 - CEG 55) tnkgurl - NECO 56) 2 guard - CEG 57) SVTatGT - CEG 58) COUGAR99 - CEG 59) johnny hennessy - CEG 60) 99Elimin8r - NECO 61) KingpinSVT - CEG (questionable) 62) greenlacougar - NECO 63) SHOgoFast - CEG 64) akronstreetracer - NECO 65) maddbeefer - NECO 66) SVTLAY - CEG 67) BCkat - NECO 68) RodneyBur - NECO 69) FrostCougar - NECO 70) fordrule - NECO 71) 99svtContourMan - CEG 72) VanCityKitty - NECO 73) GForceAuto - NECO 74) 98_HO_Contour - CEG (questionable) 75) A-TownSVT 76) 77) 78) 79) 80)
Posts: 1,336 |
Updated List:
1) goalcoach - CEG 2) FastCougar - NECO 3) lbizboy - NECO 4) Pyro81 - NECO 5) qkilobyteq - NECO 6) EternalOne - NECO 7) vodfan - NECO 8) mont - NECO 9) predator - NECO 10) aircougar - NECO 11) getlucky151 - CEG 12) WildChild - CEG 13) Mkingracing - CEG (questionable ... in or out???) 14) Russell-3L - CEG 15) SvtEdwardo420 - CEG 16) Aspire - CEG 17) Titan - CEG 18) BSOELMAN - CEG 19) R_G - CEG 20) RawBurt - CEG (questionable) 21) zakatak - CEG 22) morbid - CEG 23) Rance - CEG 24) tropictour - CEG 25) tour96se - CEG 26) zgendron - CEG 27) NVSVT (SVT) - CEG 28) NVSVT (SE) - CEG 29) DaddyPhatSacks - CEG 30) owen_SVT - CEG 31) 99contourdriver - CEG 32) 04marauder - CEG 33) jaged - NECO 34) svt4svt - CEG 35) Blackwidowsvtt - CEG 36) bensenvill - NECO 37) Kokopellian - CEG 38) svttour - CEG 39) bigMoneyRacing - CEG 40) cvsmightymouse24 - NECO (questionable) 41) 303GreenDestiny - CEG 42) frodog31 - CEG (questionable) 43) topjoe - NECO 44) Bennett9000 - NECO 45) Nick98CSVT - CEG (questionable) 46) LancasterSVT - CEG 47) Res - NECO 48) JaxCougar - NECO 49) Bridge - CEG 50) ButtonPuncher - CEG 51) Christian - CEG (questionable) 52) Jeffs2000BlkSVT - CEG 53) Jorgen - NECO 54) Viss1 - CEG 55) tnkgurl - NECO 56) 2 guard - CEG 57) SVTatGT - CEG 58) COUGAR99 - CEG 59) johnny hennessy - CEG 60) 99Elimin8r - NECO 61) KingpinSVT - CEG (questionable) 62) greenlacougar - NECO 63) SHOgoFast - CEG 64) akronstreetracer - NECO 65) maddbeefer - NECO 66) SVTLAY - CEG 67) BCkat - NECO 68) RodneyBur - NECO 69) FrostCougar - NECO 70) fordrule - NECO 71) 99svtContourMan - CEG 72) VanCityKitty - NECO 73) GForceAuto - NECO 74) 98_HO_Contour - CEG (questionable) 75) A-TownSVT - CEG 76) Spade - NECO 77) 78) 79) 80)
