Guys you have plenty of time to save for this. I invision an end of March time-frame. So put away at least ~$150 for the bar and bushings, and if you want the endlinks form me, stash another $65.
The subframe beef-up is HIGHLY recommended. You don't have to go through ATI, you can do this yourself if you have someone who can cut and weld - WELL!
1" x 1" box tubing is what's needed. I'll try and make up a piece to simulate what you'd need, and post pics soon. In effect you need to remove the stock sway bar monting tab, notch out the frame to accept the square tube, and weld into place in the same location as stock. Vio la, upgraded subframe.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
