Posts: 1,241 |
definitely be careful with the vacuum hoses. i put my alternator on my old zetec (pain in the ass) and didnt realize i knocked one off. took me a while to find out that thats what it was. the hardest part for some reason was getting the belt tensioner to loosen.
Jake
96 T-Red SE V6
Posts: 1,572 |
Originally posted by GetLucky151: I dread the day I have to change my alternator in my Duratec.
I helped a friend do his, i can change out the complete suspension, coil / springs FASTER then doing alt swap .
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
Posts: 466 |
wish me luck, its my turn to have a go at this
98 contour svt
#6473 of 6535
Posts: 7,100 |
PM me, or email me (ceg.ray AT Gmail.com) if you need help.
Ray
'99 CSVT - Silver #222/276
Posts: 1,145 |
Originally posted by Dakmis: wish me luck, its my turn to have a go at this
ditto will be removing it to have it tested in about 5 hours then i will be rerunning the wires between it and the batt.
98.5 Black SE ATX
Posts: 466 |
Originally posted by gearhead98: Originally posted by Dakmis: wish me luck, its my turn to have a go at this
DONE!
after i got off my butt it only took about 3 hours to do everything.
longest part was running my dead alt to napa to trade them for the new one.
98 contour svt
#6473 of 6535
Posts: 2,446 |
Ive pulled that thing so many times that each time i do it, i find something new and easier. the car has been torn down plenty of times to work on the timing system, and its one of the thinsg that has to be removed. But the alternator finaly took a crap on me so we got a brand new shiny one now to!! this is a all to familiar site
Posts: 2,166 |
It looks like a few pictures are mis-linked. Any chance of getting those corrected?
- Zack
WANTED: T-Red HEATED Side Mirrors
FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps
2000 T-Red SVT
1995 LX V6 MTX (RIP)
Posts: 7,100 |
read "ray's how-to's" post. correction is underway (I am in contact with imageshack..)
Ray
Posts: 21,197 |
Did my first alt. replacement for a CEGer this weekend. My tip: Get about 4' of extensions yes 48". Remove the driver side splash shield. Run it all the way through to the top alt. bolt. (Won't work on a car w/ headers). On a car with headers for the top bolt I removed the coil pack/plug wires & 2 harness nuts. Moved the harness out of the way. I then used a 13mm socket, 3" extension, u-joint and 18" in extensions to angle it up to the engine area to get a 1/2" rachet on it. For the center bracket I able to get my hands in there and use a 10mm gear wrench. You can also use extensions. Just need to remove the one attached to the bracket. You can remove the entire L bracket when the alt. is out. On the bottom I was able to use 12" of extensions and a 1/2" drive to get that one out. For the 2nd/middle clip on the alt. I used a pick similar to the one pictured here on the far right. The 10mm bolt/megafuse connection I used a 10mm gear wrench and for the top clipped connection I just used a long flat head and popped it off. I can probably do a swap in about an hour now. Stop making it sound so hard.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
