Page 3 of 3 1 2 3
#1176766 02/20/05 11:28 PM
bucking/hesitation at more than 50% would either be TPS or spark... maybe the wires, or coil need "refreshening".
2-2.5 YEARS on the plugs and wires could be about time to change them, mileage dependant.
Coil pack, maybe not so much, but a possibility, still.
Ray - a former SECEGer..
#1176767 02/21/05 03:26 AM
U
U
I had the same hesitation problem and new plugs/wires fixed it. I'd start there since they are the easiest.
2k silver svt #1721 Ignorance breeds stupidity..
#1176768 02/21/05 04:57 AM
i was having the same sort of problem with my 96 gl and basically i did what had never been done to the car before...i cleaned the friggin' injectors with some o' that nifty lucas injector cleaner and voila and fibiniccio, problem fixed. that and i changed the oil and air filter but that's just reg. matinence (sp?) so if you do that regularily then it's most likely the injectors. unless you actually do have a bad wiring connection, but you said you replaced plug/wires so i was just giving another suggestion.
-Contour's dead, but is being revived...
Originally posted by CSVT1214:
Originally posted by ford zetec2:
after than, what do i do with the 98 short shifter? do I place it in there like it is?
Stick it in your butt and rotate.
#1176769 02/21/05 06:36 AM
U
U
I would still try new plugs and wires first. Mine were only 3 years old if that since I had changed them and as it turned out they were the prob.
#1176770 02/22/05 02:28 PM
yeah, i agree but i was just suggesting that it may be something a little cheaper, but w/e
Page 3 of 3 1 2 3
Moderated by  Lee_dup2, unisys12
