Page 2 of 2 1 2
#1176741 02/08/05 10:29 PM
again...this is 1st operation, next operation would be to install piece into a indexer on milling machine and machine large round end into a square and machine a flat on the small end of the pin...then drill the 2 holes and slot accordinly to match the stock mounting pins. the slots would give u the adjustment needed for the alignment. we'll post pics after they're finished.
1998 CSVT E0 3L son's car - http://www.cardomain.com/id/svturbo 1998 CSVT E1 (Future 3L) daughters car Get in, sit down ,shut up, hold on
#1176742 02/09/05 06:00 AM
9
Do we have an estimate on cost? I love my car but hate spending money on it unless it makes it go faster, because if it gets wrecked I will get almost nothing for it.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
#1176743 02/09/05 06:48 AM
I am very interested in these too
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
#1176744 02/09/05 04:34 PM
Can't wait to see your finished product. Did you leave the stock sleeve in the arms or press in a new 1?
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
#1176745 02/09/05 09:43 PM
new inner and outer sleeves were made...the stock ones couldnt be used due to the fact they were mangled severely and the fit of the sleeve to the bushing wouldnt be perfecly flat like it is supposed to which would mostly likely cause severe squeaking. urethane bushing in general do squeak but not like wut it wouldve been if the old sleeves were used
Page 2 of 2 1 2
