Page 2 of 3 1 2 3
#117660 04/26/02 02:58 PM
DemonSVT,
Are those stock headlights? Or did you mod the mirrors? Running Xenons?
'98 Black SVT #651 of 6535
KKM Intake (Miks Heat Shield in Winters/Drop-in K&N Summers), SHO Y-Pipe, and Bassani Exhaust.
Eibach Pro-Kit, Koni Struts, and Enkei RS5's with BFG-KDWs (215/45-ZR17)
BAER 13" big brake kit+rear baer rotors all zinc washed, cross-drilled and slotted (Greenstuff binding rears)
Kenwood head unit with Infinity reference speakers+1 8" Bazooka Tube fed by two MTX Blue Thunder amps.
Hella Stage II HIDS from hids4less.com.
Recaro Sport Seats trimmed in supple black leather.
And Zymol wax to keep it squeaky clean.
#117661 04/26/02 03:30 PM
E
E
Nice, what kind of filter is that?
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
#117662 04/26/02 04:52 PM
Where is the fuse box?
98 E0 Silver SVT
KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
#117663 04/26/02 05:08 PM
Me too on the PCV Oil seperator!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
#117664 04/26/02 05:15 PM
Administrator
Administrator
Hurry up DemonSVT! I want to know about the filter, too!!!! :p
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
#117665 04/26/02 05:36 PM
Originally posted by DemonSVT:
Filter is a K&N RF-1027 with a modified KKM adapter.
Silver canister is an Oil seperator for the PCV system (No more gunked up intake!)
STB is from a Honda Accord. (92-97 IIRC) I had to make spacers to compensate for it's short length.
They are nicely hidden by the inner liner.
It's bolted in with large body washers on the back side.
L3rn tu reed!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#117666 04/26/02 06:58 PM
Administrator
Administrator
Originally posted by L8 Apexing Aussie:
[b]Filter is a K&N RF-1027 with a modified KKM adapter.
L3rn tu reed![/b]
I can read fine! It doesn't say what KIND of oil separator! Model?
-Lance
Lance Kinley
CEG Webmaster
#117667 04/26/02 08:18 PM
Lance, I didn't see any question from you regarding the oil separator, but anyways...it's all good. wink
His oil separator is a home-made. I can tell. It's a 2" (maybe 3")PVC pipe with two PVC encaps glued on. Then two brass screw-in barbs and finally a brass screw-in drain cock in the bottom. Paint it silver an viola!
Cost you like $15 for all the parts from Home Depot. How close was I Greg?
Man I should make a bundle. Anyone intereted?
Regards,
Anastazi
#117668 04/26/02 09:20 PM
Administrator
Administrator
Ah! I guess I just didn't look at it that closely. I'll make a trip to Home Depot! :p
-Lance
Lance Kinley
CEG Webmaster
#117669 04/26/02 10:20 PM
Hey, go for it. I have little time to make stuff like that & would probably cough up $30 or so if you included install instux. smile
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Page 2 of 3 1 2 3
