Posts: 1,012 |
I've got a vibration in the steering wheel that can be felt throughout the cabin at highway speeds. The car just got aligned and none of my wheels are bent or off balance. Any clues? I searched and got alot of results but nothing conclusive. Trying to get an idea before I take in to the shop...
Posts: 2,542 |
sounds like its the tires
get em balanced again
Posts: 313 |
Or do this quick test:
Rotate the tires, front to rear.
If the vibration moves, it's definitely the tires (or wheels).
If the vibration doesn't move, it might possible still be a tire problem, but it's less likely.
1995 Contour GL V6 ATX T/C
1986 Mustang GT 5.0
2000 Windstar LX
Posts: 1,012 |
What kind of tire problem, they are brand new? A balance problem? I'll check it out and give an update. Thanks for the info.
Posts: 2,061 |
its possible to have a bad tire even if its new...mom bought a defective goodyear from sams club...had it balanced 3 times before it was replaced with a good tire...thing bumped like hell
99 expedition eddie bauer, 5.4 v8, k&n drop-in, 3" magnaflow catback and gas mileage that makes the contour look like a hybrid
Posts: 5,143 |
listen to the suspension to... my steering wheel vibrates when at freeway speeds also... The reason why is because I have a bad sway bar link on the driver side, if you hear clunking coming from the front, it would be a good time to replace your sway bar links.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 8 |
I had the same problem, thought it was the tires, so i took it in to get the tires balanced and checked, turns out that my lower ball joints were shot, and stabilizers were going too
Posts: 2,033 |
Originally posted by FreeShyne: What kind of tire problem, they are brand new? A balance problem? I'll check it out and give an update. Thanks for the info.
Yes most likely an off balance tire. My mom had this same problem with her exploder, it would vibrate very noticeably after about 50mph...just took it to get it re-balanced...and POOF problem solved.
