#117544 04/22/02 04:24 PM
sordz Offline OP
hi all i was wondering what computer chips if any you have in your svt's? i have a 98 svt and cant decide on a diablo or a superchip, can anyone help?
thanks
tony
#117545 04/22/02 04:36 PM
I have a 98 CSVT. I used to have a superchip, but at a recent dyno run I saw that I lost 5 hp in the top end. The guy running the dyno said this is common on mildly modified engines. All I have is a KKM intake and a Mass Air Meter. Maybe your setup is different enough to warrant a chip, I would spend the $250 on something else.
Ground Control Coilovers
Koni Adjustable struts
Sub-frame connectors
Slotted rotors
Carbon Fibre pads
Stainless Steel Braided line
KKM Intake
Pro-Flow Mass-air Meter
22mm rear sway bar
Polyurethane motor mount inserts
#117546 04/22/02 05:13 PM
9
9
Judging by the gains folks have gotten on here, I would save your dough for a mod with documented gains, like an off road y pipe or the Apex'i S-AFC or possibly a new Pro-M MAF with calibrator. The reason I say this is that I put the correctly coded diablosport chip on my SVT that just had intake and exhaust and the chip was dyno proven to cost me 8 hp (173 witout, 165 with) and 6 ft lbs of torque (155 without, 149 with) with losses documented all along both power curves. Knowing what I know now, I do not think I will ever buy another off the shelf chip. I plan on eventually getting an autologic chip based on a professional dyno-tune for my new mustang way out in the future after all my mods are done.
Just my 2/100 of a dollar based on some hard learned lessons. Don't waste your $250 unless you have a stock car...but if you go with one the superchips seem to be better for the tours.
Former owner of 1999 SVT Contour #555
#117547 04/22/02 05:44 PM
H
H
i am also using a superchip it aint bad but i am going to get a autologic chip as well a local shop is doing some great things with them
#117548 04/22/02 05:56 PM
Once Autologic actually writes the program for the Contour/Focus PCM... frown
I too will be in that line whenever they do... laugh
2000 SVT #674 - Check it out!
#117549 04/22/02 08:06 PM
sordz Offline OP
WOW! i didnt think it made a car slower, i guess that 20hp that they say you will get isnt for a car with only intake and exhaust. well thanks for the info and saving me money.
#117550 04/22/02 10:31 PM
well i think they say 'up to 20' or whatever the figure may be depending on your car...
i've been wondering about something for a while and this post reminded me again....
taking into account that some of u are or have seen losses instead of gains on slightly modded cars...maybe it would be a good idea to get a chip first on stock car to get the gains it may give u....and thennnnnnnn....to add intake and exhaust on top of that instead of adding the chip to the intake/exh
any thoughts???
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#117551 04/23/02 12:33 PM
To be fair to diablo and superchips, significant mods to intakes or exhausts can cause horsepower loss. If you have no cat, gutted pre-cats, a y-pipe or true duals, you will probably see a loss since the stock program can not compensate for that.
On the other hand, if you are like me with just mild exhaust, electrical and intake mods it can make a big difference on an ATX.
Kharma is very real and she is one mean b!tch.
#117552 04/23/02 12:51 PM
H
H
like i said my superchip isnt bad on the dyno i gain hp and tq esp in higher rpm above 5600 and that is without a custom burn just a standard burn
