Posts: 1,367 |
Pure water will always freeze at 0 C. Keeping it moving just cause friction within the molecules that causes the water to heat up. Friction does that.
Salt (and for the most part any dissolvable substance) in water interacts with water molecules, not allowing them to bind with each other when they slow down thus lowering the temperature at which point the solution freezes, because the salt molecules must slow down as well. I believe the lowest possible temp with salt water is 21 C.
And I hated Chemistry.
If you want something cool to look up, do a search for Absolute Zero.
Sal Khan
00 SVT - Not pretty
00 Aprilia RSV Mille - Also Loved.
http://www.thelunchjournals.com
"I just want someone I can stand once her mouth is free of obstruction."
Posts: 21,653 |
Originally posted by LilRedRocket: Ice stays at the same temp, just like boiling water, once it reaches that 212.5 degree mark, it boils... you can add all the heat you want, and boil it with a plasma cutter for all I care, but it still won't get any hotter. ANd the same goes to ice
Can you show some actual proof of this? You keep adding heat to water, it will reach more than 212.5 degrees. That is just when it STARTS boiling. Water also freezes at 32 F AND stays frozen as it gets colder, it doesn't stay 32.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,741 |
wow lately threads having been jumping off like crazy
this is gettin rediculous!
1997 Civic CX (lsvtec,el frontend,fast, nuff said)
Posts: 136 |
Originally posted by Ray: Ice is never colder than 32�ºF.
Iceburg or not, its only 32....
THE WIND SUCKS THOUGH!!!
Ray
Uh...yeah...
No ice definitely gets colder than 32 degrees F, other wise there would be no purpose or the equation Q=mc(Tf-Ti)...This equation will tell you how much energy it takes to raise the temp of ice from say 0 degrees F to 32 degrees.... and yes i hate chem too.
'88 Camaro SC 305 The "new" car.
Rear wheel drive is great!
'00 Honda Civic si EPB, STOLEN 11/25/05
Miss my baby, now my little bros car.
'96 Contour SE w/ '98 svt exhaust w/
Dynomax res and mufflers
Posts: 1,367 |
You've obviously never heard of Superheating then. Originally posted by LilRedRocket: Ice stays at the same temp, just like boiling water, once it reaches that 212.5 degree mark, it boils... you can add all the heat you want, and boil it with a plasma cutter for all I care, but it still won't get any hotter. ANd the same goes to ice
Sal Khan
00 SVT - Not pretty
Posts: 43 |
Or used a pressure cooker.
'00 SE...that's all
Posts: 7,100 |
You are right.. I was wrong..  Ray
'99 CSVT - Silver #222/276
Posts: 328 |
1. Escape 2. Jeep liberty 3. MR2 4.
1999 CSVT-Black 15.8@89mph
Driver for hire. PM me.
