Page 2 of 2 1 2
sure, np, ive got some stuff to do now but ill post them this afternoon
" 90 percent of all chevys are still on the road. The other 10 made it home " 98 se, 2.5 V6,black,ATX Cleared and silverstared, Hella Optilux, resonatorless, Kumho ECSTA 716s and Dunlop SP Sport A2s
its 1 inch near the grill and 3 1/4 inches near the fender (from the top edge to the bottom edge of the eyelid)
it took ma a while to figure out how to do these. there no patterns to follow and you really cant make a pattern because everything is curved. What i did is cut out a large retangle much bigger than the size of the eyelid you are going to make. make sure your headlights are clean and remove the backing of the vinal. start applying the vinal to the top of the headlight and smooth it down. then slowly peal the excess back up untill you reach the top line (of 3 on the headlight lens). now make a crease at this line. as you make these creases, do them in sections and it will be easier to follow the line. once you do this all the way across then cut carefully along this crease with a small knife or utility knife. thats it. sorry i dont have any pics of how to do it. good luck! Ask me questions if you need more help
note: as your applying the vinal make sure to try to stretch it as much as possible to prevent bubbling when it gets hot.
Page 2 of 2 1 2
