Posts: 9,602 |
Originally posted by svtProdigy: but the runners are TUBULAR not OVULAR for better flow
That's not a true statement though.
An extrude honed intake would have better flow characteristics then a similiarly set up tubular because the inner ports are cut and smoothed just like the air would flow.
It would also have the ability to be made better by maximizes the honing.
With a cast EH'd manifold there are no multiple angles.
No multiple weld joints.
No sharp corners.
Et cetera...
Tubular does not necessarily mean better in any design.
Check out my website. I have good information and theory on port size, shape, and manifold types.
It's been updated recently and I'm putting more on my notes online again.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,190 |
There are no sharp corners. weld joints are smoothed out in side it. This was extrude honed. We are talking about my tubular intake right? It is known tubular flows better than ovular I had it on my car and noticed a huge difference down low and up top in the rpm range.
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 1,190 |
demon what do you think about the design of wagners intake? It seems like a simple design. You could pretty easily imagine the inside. looks pretty sweet. I really am thinking of buying one. He of course would grind down the welds and clean it up a bit.
#702 of 2150
Posts: 110 |
i dont like the looks of it..i am cuurently designing my own custom aluminum manifold based on the one shown in the link below. (its for a mustang) runner length is the thing that has me, or does it not matter w/ a turbo.
http://www.need-4-speed.com/proturbo.htm
also anyone look under performance engines and see eagle H-beam rods & JE pistons for under $400..wunder if their for the duratec?
Posts: 4,292 |
Originally posted by svtProdigy: make an offer....and remember this thing is the actual prototype for our svt but the runners are TUBULAR not OVULAR for better flow
pm me and we'll talk
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 9,602 |
Originally posted by svtProdigy: There are no sharp corners. weld joints are smoothed out in side it. This was extrude honed. We are talking about my tubular intake right? It is known tubular flows better than ovular I had it on my car and noticed a huge difference down low and up top in the rpm range.
Any time you weld it together there are seems ,corner, and angles. Period!
Extrude honed tubular intake.
It's a fact the prototype manifold did no better then an extrude honed stock split port. Also with extrude honing you are certain the airflow to each respective port is the same.
You're just making this shtuff up as you go along aren't you.
2000 SVT #674
Posts: 9,602 |
Originally posted by svtProdigy: demon what do you think about the design of wagners intake? It seems like a simple design. You could pretty easily imagine the inside.
I don't like it personally.
Also how can you imagine the inside. You can't see how the runners are attached to the plenum.
I don't see that being a good design at all personally. Then it's said it was built for a turbo...
2000 SVT #674
Posts: 1,190 |
Originally posted by DemonSVT: Originally posted by svtProdigy:
(It's a fact the prototype manifold did no better then an extrude honed stock split port.)
Where might you be getting your (facts) from? Watson engineering? Otherwise is not stated anywhere.
I have personally drove the car with it on and felt the differences. This manifold is about 2/3 the weight of the svt upper intake shaving some weight off the car. Either way its lighter, tubular and one of a kind and don't forget looks awesome. If it flowed the same as the svt manifold then there is still something to gain.
#702 of 2150
Posts: 2,676 |
i really don't think weight savings off of your UIM will actually enhance your performance. . .the SVT UIM isn't that heavy for an all aluminium UIM anyways, and most importantly, for people like Demon and myself who've EH'ed the crap out of it, there isn't much left in there!!!
I wish I would've measured pre and post dyno measurements of the extra EHing on my UIM, but alas, one could only surmise that the extra smooth lining inside (which THAT design CERTAINLY doesn't have) can only enhance the flow. . . .
Posts: 1,859 |
You can kind of see the runners in one of the pics. There short, obviously good for turbo, and what I can make out, the center "plate" section,or what maybe a plenum, just appears to be a cover if anything. Looks basicly like a tube welded around all of the ports, failry similar to a 2.5 manifold, but picture it with small runners only. Hard to tell but the tubing appears to be a little on the large side, I guess depends on what he is trying to accomplish. Not the best looking thing around, but if it works.....
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
