Can someone post the web site were to can plug in any tire size and it will give you the overall diamater(spelling) and compare to other sizes as well...
thanks guys
98 csvt t-red.. sho-shop intake, b&m, fidanza, spec1 clutch, Torsen, DMD,optimized Y& TB, Brullen, rear strut bar,h&r's,17" konig traffik's. "I say what I mean and I do what i say"
dion 98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
thats the one thanks dion.
I didnt think i would get a response so quick esp. at 1:30am
You can also go to Tire Rack and check the specs on diffrent brands and models of tires. There seems to be a bit of variance between manufacturers, even within the "same" tire size. I think this variance is one reason that some people rub with the "same" tire size, when in reality, they are not the same. When I was looking for tires a few months ago, between Goodyear and Yokohama, I think there was around a 0.75" difference in Tread Width between the two in the same size tire! Presuming they measure them the same way, that could definately account for one person's tires rubbing while someone else's don't!
Marty
98 SVT, Black, No. 786, May 7, 1997. K&N, MSDS, Xcal2, Tint, Antennas, Big Gulp(R)-Sized Cupholder, Rear Dome Lt., Koni/Eibach, DMD, Pre-98 Sails, Brake Cooling Deflectors, Sidemarkers, Etc. 147K+ Miles "Get the Door - It's GrooveNerd!"
You can also try this. I like this one better because you can compare sizes side by side. Tire Size Calculator
1999 Ford Contour 2.5V6 5peed Se Sport. Aim djperico Looking for svt front and rear bumpers.
Thanks for posting this URL. 1010tires.com has done a great job with this calculator!! Bill
Moderated by  1314_dup1
