Originally posted by Dan Nixon:
So what is the theory behind this..advance spark??
They theory behind this is to have the PCM dump more fuel at throttle tip in because it thinks the throttle plate is open farther then it is.
The theory is flawed and the PCM will tune out this mod.
When the car starts up and the PCM sees closed throttle position/voltage. That's the value it gives for closed throttle. In order for you to change that you would need to alter the TPS position enough to get past the low range of values so the PCM thinks the throttle is open.
This would slightly increase part throttle fuel enrichment. However it would also cause the car to run rich (as if it doesn't run RICH enough to begin with) This in turn would cause the PCM the "trim back" the fuel enrichment in order to stay around stoich. Therefore tuning out this mod.
OBD-II is all over part throttle A/F using short & long term fuel trim data. It will not let the car run abnormally rich (or lean)
I, of course, am the devil for mentioning this over & over... :rolleyes:
