Posts: 392 |
I have a 99 tour w/out the indash clock. If i buy the clock assembly is hard to recontent it?
I've already pulled out the existing trim with my LED and i don't have the connector for the clock.
I do have the wiring diagram, it's suppose to have 5 wires to the clock.
1 for the ground, that 1 should take from the radio; 1 for the PATS system, that i might run the wire from my existing LED; 1 for the lightning of the clock that i can take from the HVAC control; 2 powers from fuse #32 and 34 from the passenger compartment fuse box, that i might take from the always hot and power from my radio. These are probably for the power on and memory.
Am'I right????
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 674 |
I just finished installing mine last night. Took all of about an hour to do. I just used the HOW-TO write up to install mine. Everything works great. Recontent Dash Clock
Posts: 392 |
Thanks for the link, did you have the connector behind the bezel or did you have to solder the wires to the clock? Cuz i don't have the connector, but might be able to get one at a scrapyard.
Thanks,
Nic.
Posts: 674 |
I went to the scrap yard to get the clock and harness. It makes it alot easier to wire it into everything else.
Posts: 2,838 |
Go to a computer repair shop & ask them if they have an extra CDROM-to-audio cable you can have (or if you're into computers , you may have one ) - they have 2 plugs , one on either end . Then (if you have to) just move the wires in their plugs & plug 'em into the clock & hook up according to the How-To . Easy as pie !
~~~~~~~ Phil
Black & Tan 2000 SVT Contour #2137 of 2150
35,000 miles & counting !
Posts: 392 |
Y2KMondeoSVT: Go to a computer repair shop & ask them if they have an extra CDROM-to-audio cable you can have (or if you're into computers , you may have one ) - they have 2 plugs , one on either end . Then (if you have to) just move the wires in their plugs & plug 'em into the clock & hook up according to the How-To . Easy as pie !
I've checked what i have from my old computer, is that something that can work? [image] [/image]
But it's only 4 wires and i have the PATS, can i reuse the old connector for the PATS?
Otherwise i will go to a computer shop ans ask for it, thanks.
Nic.
Posts: 2,838 |
The (computer) wire I used looked similar to the one on the right in your pic , but had 3 wires in it (red-<skip>-black-white) with a socket on either end (the same style socket) . I just popped any wires (from the black connector) out that didn't correspond with the back of the clock , and popped them the right spots . To make the needed 8-pin plug ,I simply used 2 CDROM-to-audio sockets stacked one on top of the other . Instant 8-pin connector !
~~~~~~~ Phil
Posts: 392 |
Y2KMondeoSVT: The (computer) wire I used looked similar to the one on the right in your pic , but had 3 wires in it (red-<skip>-black-white) with a socket on either end (the same style socket) . I just popped any wires (from the black connector) out that didn't correspond with the back of the clock , and popped them the right spots . To make the needed 8-pin plug ,I simply used 2 CDROM-to-audio sockets stacked one on top of the other . Instant 8-pin connector !
Good i'm gonna try the 2 CD-ROM-to-audio. I also took, from a 97 tour at the scrapyard this connector. [image] [/image]
[image] [/image]
But the clock bezel is not the same, it's the 2 or 3 pieces one. So i'm not sureif this connector can fit on the 98 clock. It's an 8 pins with 4 wires in it. It has another connector for the PATS. Do you think it will fit?
Nic.
Posts: 3,065 |
When I was taking a quick look at FCO today, I saw someone who put the clock in, but somehow reversed the polarity and made the numbers black, with a blue background. Indiglo-like. Looked really hot  .
Here it is:
(since it is a bmp, I can only put the link)
pic
Posts: 4,294 |
 I am now hosting a jpg version of that... Wow that is hot, that would look great in my old car, if i hadn't made mine white instead. can you get an email addy to the person who did that. Or send me the link to the page so I can PM him on FCO.
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
