Posts: 685 |
Hey guys my battery is shot. Well it will light my interiors and whatnot but when i go to start all i hear is clicking (im guessing from the starter). This has happened b4 and started right up from jumping the battery....so i guess it has to be the battery.
My question is...I need a new one and I've heard redtops are the best especially for audio setups and whatnot, but I hear their VERY expensive and you need to do some modification to make it work. I need an easy drop in and go battery but one that is pretty darn good. I plan on getting a new Alpine recieiver and then amping some 5x8's in the near future and then perhaps may run a sub or two (12's) off another amp in the distant future.
What battery should i get? I dont want to spend too much but then again i want something good. I went to National Tire & Battery and they have a replacement for the contour which is a "vented" battery??? Not sure what this is or what brand it was. Anyway its rated at 675. Factory is 590. Is this strong enough for my situation? suggestions welcome.
Thanks
Justin
98.5 CSVT # 4887 of 6535 (born 2/28/98)
Posts: 192 |
Personally I would recommend a Gel (not the brand name)type battery. Those are gonna have minimal to no gassing accuring in the batter, it has more plate surface area (more amperage), and will last you quite a while and the power rating is outstanding if you ask me. A typical fully charged batter is suppose to run 12.6v, but we tested my friends gel and it was puting out a little over 13v. The amp ratings are great too. But the price on these batteries can get high. I believe they start somewhere around $120?
1989 Toyota Corolla (Totaled, now father car)
1990 Isuzu Trooper (Sold for more than bought)
1998 Ford Contour SE (Totaled in moutains)
1990 Toyota Supra (Blown head gasket)
1998 Ford Contour SVT (So far so good ::knocks on wood::)
Posts: 8,301 |
IMO, get the highest CCA, highest reserve battery you can afford and will fit in the car.
-Ken V.
psycho_bass@hotmail.com
Posts: 685 |
I don;t know anythting about gel bateries..where to buy,how to maintain,their CCA,their cost, etc
well thats the thing...when I went to NTB they only had one battery to fit the Contour and its a vented battery (whatever that means and if its good or not)? It puts out 675 CCA compared to factory 590 CCA and is $65. But i don't know if this is strong enough for my needs.
Any other suggestions? Am I correct you need to do modifications for the Red/Yellow top to fit/work?
Need help ASAP b/c I need to buy this battery today b4 the stores close so I can run my car this week.
Thankyou.
Justin
Posts: 192 |
well, the only other suggestion I have for you is not a battery... I mean the batter is only used to start the car, once the car is started then the battery doesn't do much but sit and get charged. If your system is taking all the power out of your battery, than another suggestion I have for you is to get a high output alternator (a pain to replace compared to replacing a battery). You can find a gel batter at Pepboys. or go to a performance shop, they should be able to help out a lot. I hear Odysey is a great brand.
Posts: 21,653 |
Just get that $65 battery then upgrade your wiring. Do the alternator to battery, alternator to ground,etc. You should be fine.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,076 |
I agree with kermie, your not running much off the battery, save the $$ and put it into the tunes.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 685 |
Originally posted by Kremit: Just get that $65 battery then upgrade your wiring. Do the alternator to battery, alternator to ground,etc. You should be fine
Originally posted by CarpePoon: I agree with kermie, your not running much off the battery, save the $$ and put it into the tunes.
Ya thats what I did the $65 battery. I Installed it today. It has 675 CCA and the factory battery recomendation is 590. However, the battery I replaced was only 500 ...so I upgraded 175 CCA
P.S. can you go into more detail and explain the upgrading of the wiring and rerouting? Kinda confused on this.
Justin
Posts: 21,653 |
I can't as I've never done it. Basically just all the wiring between the alternator and battery, and alternator and ground, and another one, maybe battery to ground (I've seen people say the Big 3, can't remember what they are). You just take that wiring out and replace it with thicker wiring.
98.5 SVT
Posts: 136 |
Is there a possibility of a how-to on the big 3 for the contour? I'm sure a lot of people on here would love to have one. I had a buddy do mine, so no mas for me...
I think, I tinker, I play around, I build.
'99 Contour
W Ztc, ATX, HID Fog, mesh, A6, B LED, Big 3, Alpine cda-9827, Memphis lvs12 1200w, Alpine 1241, 4xInf K 6x8, Xfire 400/4, 7.2 LCD, glv box "xbox jack" mod, interior horn alarm mod
