#1170205 01/29/05 09:01 PM
What is the ideal launch RPM's on tours. I have an SVT if the Duratec vs. Zetec matters. I was just curious on the issue.
~Alex
#1170206 01/29/05 11:14 PM
The RPM of the launch is equal to the slip of the clutch. 'nuff said!
#1170207 01/31/05 01:59 AM
Bone stock SVT, any suggestions now?
#1170208 01/31/05 02:49 AM
9
For drag racing?? I've heard you should leave like you're leaving the grocery store and then nail it...
Try 2500 and go from there...
What kinda tires are you running?? The batter the tires, the harder you can launch it. But, if you start to get wheel hop, BACK OFF!!!
Spin =
Hop =
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
#1170209 01/31/05 02:23 PM
There are too many variables to give a numerical answer as to where the rpms should be at launch. You have to take into account the tire grip, the wear of the clutch, the track conditions, etc... The best way to figure it out would be practice, and do whatever works best.
Cameron 98 Black CSVT #2958
#1170210 01/31/05 08:47 PM
Working the clutch out is way more important than launch rpms. You can get a strong launch from only 2k or so if you let it out a little slow then quickly. Just play around until you get a strong quick pull.
2.5L MTX-75 SE
#1170211 01/31/05 11:01 PM
3300 with my 98.5 on BFG Traction T/A's
with the old duncraps I couldn't launch higher than 2500, and even then, i'd get nasty wheelhop from 6-7k.
P2 91 tsi awd, not stock P3 98 CSVT, stock
#1170212 02/02/05 03:44 AM
Between 2000 and 3000. Normally around the 2500 will work best. Anything higher and you will probably start burning the clutch, due to the fact you have to slip it so much. Or you will just have mad wheel spin.
Mazda 6S, V6, Speed Yellow 5 Speed, Sport package Bose audio Painted 'stash and HIDs! w/Injen 1/4 14.750 @ 94.94 Former car: 99 Contour SE Sport Black MTX V6 SVT plastic... 1/4 - 15.012 @ 90.58
#1170213 02/02/05 11:12 PM
I usualy do what those drag hondas do and just stage with my right foot on the floor and just let it bounce off the rev limiter. and then when it goes green i just slip my foot of the side of the clutch pedal. Works everytime.
98 csvt t-red.. sho-shop intake, b&m, fidanza, spec1 clutch, Torsen, DMD,optimized Y& TB, Brullen, rear strut bar,h&r's,17" konig traffik's. "I say what I mean and I do what i say"
#1170214 02/03/05 12:45 AM
Q
Q
I would love to see a vid of that... my tranny would take a crap if i tried that!
#3162 of 6535 98 SVT Silver frost Viper Responder 791 w/ 2way remote start Let the modding begin!
Moderated by  mbb41_dup1
