#1169959 01/29/05 07:12 AM
Okay here's the question for the day:
when I rev my 95' up to/past 4000 rpm, there is a loud knocking sound. I haven't been able to locate exactly where it's comming from however it's actually powerful enough to noticably shake the car. Any ideas?
cylinder mis-fires?
has anyone else encountered this?
Contour 95' LX V6 120K Stock to the block
#1169960 01/29/05 07:55 AM
I am Canuckian
I am Canuckian
Is it persistant or does it only do it once? For the record 4000 rpm would be just past the IMRC opening and could therefore be related some how.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#1169961 01/29/05 01:01 PM
It's pretty constant - I thought @ first it was just b/c of the cold, howver i tried it again after driving for about 30 minutes and same thing.
It sounds sort of like the mustang fast and the furious two - when they do the sprints to the pilon - @ least in regards to the knocking sound.
#1169962 01/30/05 04:34 AM
I'd be takin a good look at your oil. See if there is any shiny stuff in there.
i know my berring didn't start makin noise til around that RPM.
How many clicks?
96 LX 3.0L MTX - Black/Tan K&N; 12lb F/W & uprated clutch 2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod; UN-tuned Mod; 3rd Gear Synro-Crunch Mod 280K on the Shell, and 40ish on the Motor... 1/4 mile?? Yeah, it's a fun daily driver...
#1169963 01/30/05 02:52 PM
Sounds like a known issue with some 95's. I had one, main bearings let go at 59900kms, got lucky back then (1997) and Ford gave me a brand new long block.
This is the worst case scenario, if the main bearings are shot, but that's what mine did, anything above 3500rpm gave a loud knocking noise, then eventually the valves would start tapping as the lifters were restricted of oil pressure due to the failure in the bottom end.
Moderated by  Gerald_dup1, mbb41_dup1
