Posts: 460 |
I am looking for the Bosch part number for the 24lb injector used in the 3L DOHC Duratec engine. I have the Bosch part numbers for the following injectors:
19lb return connector 19lb returnless connector 24lb return connector
I am working with a Bosch distributor and only need this one part number then we can begin selling these injectors. As more and more Cougar/Contour owners upgrade their engines, larger injectors will be necessary. If anyone has a light blue 24lb injector from a 3L Duratec, please post what the numbers are on the side of the injector.
Thanks,
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 1,559 |
I have a set of 24Lb returnless injectors off the 2001 3L.
The maker appears to be Denso and not Bosch.
The Ford Part Numer is: YL8E-C7B
Posts: 460 |
Interesting.... so the connector is the "oval" kind that works with the returnless harnesses on Contours/Cougars?
what are the numbers on the side of them?
anything like 0 280 155 715?
Nikolas
Posts: 45 |
Also, check some Mustang suppliers as some offer adapters to use old style inj. with new style wiring.
Posts: 1,559 |
I have the injectors at the office I'll post pictures of them tommorrow, however they aren't blue they are white. Also the wiring connection on the injector is oval. I pulled it from the fuel rail to look at it more closely.
Posts: 1,559 |
Posts: 460 |
Interesting.....So Ford is using some Denso injectors......
This is what I have so far in working with my Bosch supplier:
0 280 150 943 19lb Return F0TE-D5A 0 280 155 715 24lb Return Light Blue F5DE-B5A 0 280 150 945 30lb Return Red F1SE-E5A 0 280 155 911 19lb Returnless Contour SVT Lime Green 0 280 155 865 24lb Returnless DarkBrown/Black
He is saying the last injector listed is one of the newest injectors.... supposedly a 2000-2001 injector. He is also going to find me a newer 30lb injector, since the Red one I have listed above was stock issue for some 1980 Lincolns!!! Bosch has newer more efficient designs.
Ianthin,
You are correct, Vortech sells adapters that can convert the the injectors to work on newer harnesses or vice versa... they cost $15 each though (times 6 is $90!!!!) I am going to try to find out who actually makes them....
Nikolas
Posts: 349 |
Did you ever get a chance to check the part numbers that I posted? I'm interested to see what they are.
Evan Groenke 1999 Silver Frost SVT #1919 183.9hp 163.7lb/ft tq @ the wheels Now bitter at Ford
Posts: 460 |
My contact only sells Bosch injectors....so I really dont have anyone to ask... but if they came out of a 3L engine, then more than likely they are 24lb, just like the light blue injector in earlier 3L Duratecs, part number: F5DE-B5A
Nikolas
