Posts: 4,777 |
thats what a supercharger does.
Posts: 4,294 |
Originally posted by Horse: thats what a supercharger does.
lmao
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
Posts: 1,099 |
With the way that belt is layed out, I'm sure he will get vast amounts of belt slippage, resulting in less PSI than expected.
2003 Sonic Blue SVT Cobra Coupe
2003 RedFire SVT Cobra Convertable
2005 Dark Toreador Red F150 XLT 4x4
2000 Black SVT Contour - Beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by MxRacerCam: Originally posted by todras: Originally posted by yoslvr442: that is way to much work for the 40 hp gain he will see.
I gaurantee he'll get more than 40hp. Come on 10 psi.
i'd be impressed if he can maintain 10 psi reliably running it off the engines serp belt.
I get 8-9 psi all day!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 9,065 |
Originally posted by auiotour: Originally posted by Horse: thats what a supercharger does.
lmao
Whoa dave, whoa.
Posts: 4,777 |
Originally posted by mmars: With the way that belt is layed out, I'm sure he will get vast amounts of belt slippage, resulting in less PSI than expected.
I dont think hell get a lot of slippage - not the best way of doing it - and I suspect hell be going through alternaters fairly often as he is using it likean idler. the belt has over 1/2 pulley wrap - thats not going to slip too often
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Originally posted by Horse: Originally posted by mmars: With the way that belt is layed out, I'm sure he will get vast amounts of belt slippage, resulting in less PSI than expected.
What he said. Looks like plenty of wrap for a small blower. He might have slippage problems if he tries to crank the boost beyond 12 psi or so though.
I'll also agree on the alternator, he runs a pretty high risk of eating alternator bearings.
Posts: 21,197 |
He's not done with it. He knows the belt layout isn't the best. He's working on a solution. At least something to add some tension. Post
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 294 |
I've been thinking, there are other ways to turn a blower other than a belt. In hydraulics, you can use a pump (whether driven off the motor or powered electrically by a little Baldor motor) to supply fluid to a hydraulic motor which then converts the fluid power to rotary motion. This would drive the blower. This would make the blower a remote set-up. You could remote mount the DC motor & pump anywhere you want (trunk??? as a little power unit). The hyd motor would have to remain with the blower and it too could be mounted anywhere you want ducting air to the TB. Also, you could keep the blower spooled up full time--Air on all the time. Still, I don't know how feasible all this would be but I thought I'd get the creative juices flowing. Regardless, space is an issue. Incidentally, I work for a fluid power distributor.
stock 1998 silver frost SVT E0 #1545 out of 6535
* K&N drop-in air filter
* DMD
* Koni's w/ stock springs
* Autolite double platinum
* Tranny cocktail
* Mobil 1 Snyth Oil @ 60K miles
Posts: 4,777 |
its an idea paul - but remember that a blower like an m90 at full rpms can take up to 100hp to run - the M90 doesnt but for instance the blower on the jag R's takes just over 100 hp to run at full rpms.
