Posts: 2,112 |
I have the KKM also. Though I didn't have any problems, I reinstalled it anyway. I removed the rubber surround and clamped it inbetween the MAF and MAF adapter. BAT has a gasket available for non-SVTs. I'd just buy the screen from Ford (or wherever; it's just plain stainless steel mesh) and do what I did. .
Posts: 407 |
Originally posted by BA_00_SVT: LBVSVT, what MAF do you have? THe C&L? if so are you getting problems with it running lean? Not that I know of. The dyno I go to doesn't have an A/F monitor. Yes, it is the C&L - check my post under 10lbs ft of TQ (a recent post by someone) for dyno #'s. I do notice the car tends to buck on low throttle, low speed conditions but I don't know if that's what causes it - could be the lack of the screen due to the C&L. Based on what JSmith is saying I'll have to try putting it back on though.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 2,683 |
I found this reading upon my new Z06. Interesting,since the SVTs intake has a straight shot into the throttle body.
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Posts: 407 |
... then again maybe not ...
Posts: 5,805 |
6-8" of 'straight' tube before the MAF = no screen,less than that = use a screen...
Posts: 422 |
6-8" of 'straight' tube before the MAF = no screen,less than that = use a screen... Another verse for the Contour bible I have an SVT's MAF screen in my Cougar, and my car runs much better with it installed.
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 5,805 |
Any car with a MAF,no screen and a cone type 'direct onto maf' set up needs that amount of straight pipe ......
Posts: 1,445 |
Originally posted by OhSigmaChi: Would this be worth trying to fabricate and put on a car that didn't come with a screen but now has a conical filter? Like mine? im wondering the same thing right now....but there is no need for u to fabricate a screen...spmotorsports sells them (i think thats the correct site)...unfortunately i dont have the link handy right now....if i find it i'll post but otherwise maybe someone else has it
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 3,248 |
FWIW, I talked awhile back to the guy at Kurtz Kustoms about "adding back" the screen (I actually had installed in my KKM). He said they had spent alot of time testing various shapes for the KKM MAF meter adapter so as to get the proper "voltage" without the screen and that it should be left off. Still do not exactly understand this but thought I would relay what was said. I took screen out and noticed no change either way (screen in or out).
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
