Posts: 4,051 |
BTW Goonz, the how-to is great. I plan on doing mine just like that. Thanks
Posts: 9,872 |
Originally posted by CSVT1214: BTW Goonz, the how-to is great. I plan on doing mine just like that. Thanks
thanks guys, I really appreciate it
Posts: 6,791 |
Originally posted by CSVT1214: Originally posted by RawBurt: When do we get to see the finished product?
Someone already has them finished.
Clicky
Damn, i like those... I see a future mod. After the rims, K&N and maf adapter
Posts: 9,872 |
heres a picture of it mounted, sorry cause of the salt and dirty car, I'll take some more when the weather will let me
Posts: 9,872 |
ok for this I would suggest you guys use washers, the nuts end up getting lose on the bottom plate as well as the connection between the fog and main bracket. You need it all to be secures otherwise all the agitation will losen up the nuts and god forbid you fogs pop out in the middle of traffic and they break..i don't want this to be my fault, so make sure u use washers or somthing that'll tighten it up and lock it my bad
Posts: 9,872 |
bad news..I spun out and hit a snow bank pretty hard  everything is fine except for the driver side bracket. That broke and now that whole assemble is lose. Its soo flippin cold out to do anything or wiring, I'm just gonna wire my new speakers for the time
Posts: 2,528 |
I want to do this mod to then intall HIDs on the Hellas, but I don't want to go through the mission and hazard of putting my head under a jacked up car (don't have jack stands) and risk making my head a waffle.
Does anybody know if the front bumper cover can come off easily? Thanks!
XL
Posts: 9,872 |
Originally posted by durateX: I want to do this mod to then intall HIDs on the Hellas, but I don't want to go through the mission and hazard of putting my head under a jacked up car (don't have jack stands) and risk making my head a waffle.
XL
just jack the front end of the car up, as for putting HID's in the hella's, I dont think that will happen, the fog light itself is vveeerry small and sealed very tightly, It would be extremely hard. I wanted to put in silverstar bulbs instead of the Hella's but it was utterly impossible due to the sealing ang the wiring.
Posts: 2,528 |
Originally posted by Goonz SVT: just jack the front end of the car up, as for putting HID's in the hella's, I dont think that will happen, the fog light itself is vveeerry small and sealed very tightly, It would be extremely hard. I wanted to put in silverstar bulbs instead of the Hella's but it was utterly impossible due to the sealing ang the wiring.
Well, I have confirmation that the stock fog lamp housings are deep enough to accept the HID bulbs, so should I just get brand new stock fog lamps (Tousley Ford has them in stock) for 40% off of list and install the HID in those?
XL
Posts: 9,872 |
XL
The lens cover for the stock ones in plastic, I dont want the HID's to melt it right out
