Posts: 1,578 |
I have easy access to mobil 1 atf and AC Delco synthetic blend syncromesh, will one of those work good and is there anything I should add (friction modifier). Or should I just go and find redline? I have no tranny problems.
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 1,578 |
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
149 HP @5900
148 LB FT @4300
Posts: 93 |
Ford Honey ... I just go with what Terry says
2002 Subaru Impreza WRX
2001 Mercury Cougar
Posts: 1,578 |
ok, so what is the "official" name for this Ford honey
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
149 HP @5900
148 LB FT @4300
Posts: 3,506 |
if you have no tranny problems, i go with the MTL i ahve bene using it for 2 years now with no problems....Ford Honey is good stuff too, but i believe its more expensive than the MTL, atleast around here it is form what im told.
Lupe
Posts: 3,037 |
I keep hearing "Ford Honey is more expensive" but no one seems to put that into dollar amounts.
Posts: 9,602 |
Originally posted by Jeb Hoge: I keep hearing "Ford Honey is more expensive" but no one seems to put that into dollar amounts.
Last time I heard it was in the $20 a quart range. (~$60 a fill) It also needs the Ford FM added to it as well. (Another $6-8)
I've had great luck with the Syncromesh. (I'm running Pennzoil's synthetic version)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,578 |
DemonSVT, So should I get 3 qts of Redline MTL or Redline MT90. I live in SE Minnesota
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
149 HP @5900
148 LB FT @4300
Posts: 9,602 |
MTL by all means then. It will be the better cold weather fluid of the two. It has a viscosity closer to the original ATF spec.
2000 SVT #674
Posts: 30 |
So no one would suggest using the Royal purple gear oil, or the RP ATF? Or has anyone tried that yet? I have 4 bottles of the gear oil here. Was going to change it this weekend to the RP but from the sounds of things I guess I need to take it back.
99 SVT #341
03 Vert GT triple black combo w/Roush kit
