Posts: 397 |
Originally posted by 98_HO_Contour: Wow, there is a lot of information here. Is is possible to have someone break it all down into one reply? First it was Redline, then it was ATF+3, then ATF+4, then there was some synthetic Syncromesh formula. I have 90K on my tranny, doesn't grind at all (as long as I push the clutch in all the way ) and I was planning on doing a drain and refill on Saturday.
Per DemonSVT:
Synth Redline MTL Penzoil Syncromesh Ford Honey (but it's $$$)
Dino - syncro problems already ATF+3 or ATF+4
ATF will never protect like a gear oil will but if you have issues already you don't want to use synthetic.
T-red E0 SVT
ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
Posts: 1,578 |
Originally posted by SVT Doood: Originally posted by 98_HO_Contour: Wow, there is a lot of information here. Is is possible to have someone break it all down into one reply? First it was Redline, then it was ATF+3, then ATF+4, then there was some synthetic Syncromesh formula. I have 90K on my tranny, doesn't grind at all (as long as I push the clutch in all the way ) and I was planning on doing a drain and refill on Saturday.
Per DemonSVT:
Some of the guys here were talking about adding friction modifiers, would I have to do any of that if I use Redline or penzoil?
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 217 |
OK, so if I already have synchro problems I DON'T wanna use synthetic like Redline MTL, right?
Posts: 1,578 |
Originally posted by Savior: OK, so if I already have synchro problems I DON'T wanna use synthetic like Redline MTL, right?
Correct
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
149 HP @5900
148 LB FT @4300
Posts: 2,033 |
What about Royal Purple's ATF fluid?? Has anyone used that, or heard if its good or not?
Posts: 37 |
The final clarification:
For RedLine MTL do I add friction modifier or not?
Posts: 93 |
2002 Subaru Impreza WRX
2001 Mercury Cougar
Posts: 3,045 |
no
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 1,336 |
A fluid IS NOT going to change the physical wear of an existing bad synchro/blocker ... it might change the degree of you feeling the problem, but the problem will still exist. Get the tranny serviced and use synthetic from the start.
Posts: 3,506 |
Redline MTL already has FM in it so you do not have to add it.
Lupe
