Posts: 19 |
Sorry , but I,ve searching for it, and couldn't find anything. I just want to know what the best tranny tranny fluid and how many quarts it takes. Thanks.
Posts: 2,446 |
i believe it is Redline MTL
Posts: 4,140 |
Redline MTL, 3 qts. I tried it, and I'm a believer!
Posts: 3,045 |
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 19 |
Originally posted by 95Sleeper: Redline MTL, 3 qts. I tried it, and I'm a believer!
thanks guys. I'm also a believer on redline wich I have on my Probe gt right now, and Also use to have it on my Mustang 5.0. Just want to make sure I was on the right direction. Thanks alot.
Posts: 1,399 |
Do a quick search for ATF+3. Some have switched to it from Redline MTL and have noticed an improvement. Given that it costs MUCH less, it could be a good way to go.
I find that Redline made no real difference when the tranny is cold from Ottawa's winter conditions. But being in Cali, you should have no problem.
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 19 |
Originally posted by Phil Rohtla: Do a quick search for ATF+3. Some have switched to it from Redline MTL and have noticed an improvement. Given that it costs MUCH less, it could be a good way to go.
Sure, I will check that out. Thanks.
Posts: 9,602 |
ATF does not protect near as well as a gear oil. It lacks the shear strength and clinging ability to properly protect & lubricate the transmission.
For reliability ATF+3 or +4 is not a suitable alternative to running a properly spec'd synthetic gear oil. It can help out with worn or damaged syncro though. You do not want to run a synthetic fluid with any type of syncro damage and the added FM in this particular ATF helps.
I am currently running Pennzoil Syncromesh. It is a synthetic fluid based on GM's Syncromesh specs. I have had excellent results with it so far. It also was only ~$4 a quart and the local AutoZone.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,887 |
I too went from redline MTL to ATF+3. I never saw felt or heard any improvement with the MTL. And the tranny if anything felt a little smoother with the ATF+3. I looked high and low and couldn't find the Pennzoil synchromesh(including autozone)
06 GMC Sierra 2500HD Dmax/ally
06 Pontiac G6 GT
05 CRF250R
FOR SALE 06 KX65 with riding gear $2700 obo
